Can I use Separation of Variables like this? (3 terms)
Separation of variables can be applied to certain partial differential equations (PDEs), but it only works if the PDE has solutions that fit the assumed form. The discussion highlights that while separation can be effective, many PDEs are not solvable analytically, and examples of those are often difficult to provide. A specific example of a first-order PDE, ux + uy = sin(xy²), is mentioned as likely unsolvable by separation of variables. The conversation emphasizes the importance of recognizing the limitations of this technique in solving PDEs. Overall, while separation of variables is a useful method, it is not universally applicable to all PDEs.
TylerH
\frac{\partial z}{\partial t}=\frac{\partial z}{\partial x}+\frac{\partial z}{\partial y}
\mbox{Let }z=T(t)X(x)Y(y)
T'(t)X(x)Y(y)=T(t)X'(x)Y(y)+T(t)X(x)Y'(y) \Rightarrow
\frac{T'(t)}{T(t)}=\frac{X'(x)}{X(x)}+\frac{Y'(y)}{Y(y)} \Rightarrow
\frac{T'(t)}{T(t)}=A \wedge \left(\frac{X'(x)}{X(x)}+\frac{Y'(y)}{Y(y)}=B \rightarrow \frac{X'(x)}{X(x)}=C \wedge \frac{Y'(y)}{Y(y)}=D \right)
... and so on.
Yes, separation of variables like that sometimes works. For example, the 2d wave equation for a vibrating drumhead is solved that way. Remember, when you separate the variables like that it will only work if the PDE happens to have solutions like that. So you can always try. Maybe it will work on a particular problem and maybe it won't.
How about this?
f(x) \frac{\partial z}{\partial x} = g(y) \frac{\partial z}{\partial y}
z=X(x)Y(y)
f(x)X'(x)Y(y)=g(y)X(x)Y'(y)
\frac{f(x)X'(x)}{X(x)}=\frac{g(y)Y'(y)}{Y(y)}
\frac{f(x)X'(x)}{X(x)}=A \wedge \frac{g(y)Y'(y)}{Y(y)}=B
... and so on.
... anyone?
TylerH said:
How about this?
In this case the left side can't depend on y and the right on x so they are both constant. If f and g are not zero then zx=C/f(x) and zy=C/g(y).
Integrating the first gives z(x,y) = F(x) + G(y) where F is the antiderivative of C/f(x).
Differentiating this with respect to y gives G'(y) = C/g(y) so your solution is
z(x,y)=F(x)+G(y) +D
OH! I was going about it the wrong way, but with the right technique, I see.
Can you, please, give an example of a PDE that can't be solved by separation (or the general form of one)?
Thanks for your help.
There is no reason to expect most pde's are solvable that way. Most can't be solved analytically in the first place. I don't think there is a general form for such but likely most any random PDE you might write down wouldn't be solvable that way, or any other way except numerically. Here's a simple first order one I just made up:
ux + uy = sin(xy2)
I don't know it can't be solved by separation of variables, but I doubt it. In fact, I don't know whether it can be solved analytically at all.
  • · Replies 16 ·
