Can Magnetism Alter Quantum Phase in Superconductors?
  • Context: Graduate
  • Thread starter Thread starter sniffer
    Superconductor
6 replies · 3K views
sniffer
in deriving quantization of flux in superconductor ring, the momentum of cooper pair p:
[tex]p=\hbar\nabla\theta=e^*(\Lambda J_s + A)[/tex]
then integrate around the ring,
[tex]\hbar\oint\nabla\theta dl=e^*\oint(\Lambda J_s + A)dl[/tex]
using stoke's theorem and integrate sufficiently deep in the ring where current density is very small, the RHS becomes
[tex]RHS=e^*\Phi_s[/tex]
and the left hand side,becomes hn where n is integer.
So the quantized flux is
[tex]\Phi_s=nh/e^*[/tex]
e star is the effective cooper pair charge which is -2e.
i got confused here,why the left hand side integral becomes hn?
The argument used by the book (Van Duzer, superconductivity page 116) is that because theta is unique or differ by a multiple of 2 Pi at each point, so the integral
[tex]\oint\nabla\theta dl=2\pi n[/tex]
why?? where does n come from? theta is a scalar function of r.
please help.
thanks.
[itex]\theta[/itex] is the phase of the order parameter [itex]\psi = |\psi|e^{i \theta}[/itex]. Since [itex]\psi[/itex] must be single valued at some specific angular position [itex]\phi + 2k \pi[/itex] on the ring, we need, [itex]\psi(\phi ) = \psi(\phi + 2m \pi )[/itex], or we need [itex]e^{i \theta ( \phi )} = e^{i \theta ( \phi + 2m \pi)}[/itex], for all m. For the phase factor to remain unchanged over integral number of traversals of the loop, the phase [itex]\theta[/itex] must itself change by only an integer multiple of [itex]2 \pi[/itex] (since [itex]e^{2in \pi} = 1[/itex]).
So
[tex]\theta ( \phi + 2m \pi ) = \theta ( \phi) + 2n \pi[/tex].
In other words
[tex]\hbar\oint\nabla\theta dl = \hbar \Delta\theta = \hbar (\theta ( \phi + 2 \pi ) - \theta ( \phi)) = 2 \pi n \hbar = nh[/tex]
Good answer, Gokul.
In your opinion, from an experimental point of view, what would be a simple method to effect a change in the phase of the wavefunction of the supercurrent while remaining below T(c)?
Creator :biggrin:
change the radius of the ring.
Creator said:
Good answer, Gokul.
Creator :biggrin:
Have a magnetic flux through the loop. That, after all, is how a SQUID works.
Zz.
True, in theory; but by what method are you going to change the length of a brittle superconducting wire while it is in the superconducting state?
:biggrin:
Zz.
Of course; externally applying B thru the loop. I should be more specific. I guess I am referring to a non-electromagnetic method of altering the quantum phase.
Creator
