Can someone explain what's going on in this code? (C++)
  • Context: C/C++
  • Thread starter Thread starter Jamin2112
    Code Explain
13 replies · 3K views
Jamin2112
I was looking at an example from here: http://cboard.cprogramming.com/cplusplus-programming/133294-passing-operator-parameter.html
Code:
template <class T> bool myfunc(bool lv, bool rv, T oper)
    return oper(lv, rv);
struct Or
    bool operator()(bool lv, bool rv)
        return lv || rv;
int main()
    bool result = myfunc(true, false, Or());
    return 0;
I'm confused about what it means to pass "Or()" into the function. "Or" is a type of struct and he's passing it in what an empty parantheses. Not sure how that has any meaning.
"In a class definition, the default access for members and base classes is private. In a struct definition, the default is public. That is the only difference between a class and a struct."
Or() creates an instance of struct Or using the default constructor (not specified, so the freebie provided by the compiler is used). Note also, and this is very important, that struct Or defines a function operator that takes two bools and returns a bool. The function operator is <return_type> operator() (<argument_list>).
Objects such as that instance of struct Or are called function objects, or functors. The C++ standard library makes extensive use of functors. The function operator is a bit funky on first blush, but it is quite powerful. Functors can hold value. Try the following, which should work in both C++03 and C++11:
Code:
#include <iostream>
// Function template for performing some operation <N> times.
// oper must be a functor that defines member functions name() and operator()().
template <int N, typename T>
void apply_N_times (T oper) {
   // Call oper as an object. Functions can't do this. Functors can.
   std::cout << "Applying " << oper.name() << ' ' << N << " times.\n";
   // Call oper as a function N times. Functions can do this, but it's kinda boring.
   // With functors, interesting things can happen because functors can hold state.
   for (int ii = 0; ii < N; ++ii) {
      std::cout << ii << ":" << oper() << "\n";
}// apply_N_times compatible class that boringly counts.
class count {
public:
   count() : value(0) {}
   std::string name() { return "count"; }
   int operator()() { return value++; }
private:
   int value;
};// apply_N_times compatible class that produces the Fibonacci sequence.
class fib {
public:
   fib() : prev(1), value(0) {}
   std::string name() { return "Fibonacci sequence"; }
   int operator()() {
      int ret = value;
      value += prev;
      prev = ret;
      return ret;
private:
   int prev, value;
};int main () {
   apply_N_times<10> (count());
   apply_N_times<10> (fib());
Jamin2112 said:
I know about function pointers (somewhat). I think I was mostly confused by the fact that there was a function defined inside a struct.
Functors are not function pointers. Functors (function objects) are moving toward making functions first class objects in C++. C++11 has gone even further in this regard. It adds std::function, std::bind, and one other little thing: Lambda expressions. Lambda expressions are massively powerful little beasties.
Code:
#include <iostream>
class count {
public:
private:
   int value;
class fib {
public:
   int operator()() {
      int ret = value;
      value += prev;
      prev = ret;
      return ret;
private:
   int prev, value;
int main () {
In function 'int main()':
Line 42: error: reference to 'count' is ambiguous
compilation terminated due to -Wfatal-errors.
What compiler are you using? It works fine for me, with gnu and clang, and with c++03 and c++11.
I was using this http://codepad.org/ stupid interpreter.
Codepad has problems. This time the problem is that it apparently is leaking std::count into the global namespace. My code works fine on ideone.com, and also works on codepad if you change count to Count.
Ok, here's my first time using a functor. You're going to think this is the most pointless program ever. Just for the heck of it, I'm making a library of functions for Group Theory. I could use some suggestions for how to improve my isGroup function.
Code:
#include <set>
#include <iostream>
template <typename ObType, typename BinaryFunction>
bool isGroup(const std::set<ObType> & S, BinaryFunction & op)
	   isGroup returns true or false depending on whether the set S
	   along with the operator op is a group in the Algebraic sense.
	   That is, S is a group if and only if all the 4 following
	   conditions are true:
			(1) If a, b in S, then a op b in S
			(2) If a, b, c in S, then (a + b) + c = a + (b + c)
			(3) There is an element 0 in S such that a + 0 = 0 + a for all a in S
			(4) If a in S, then there is a b in S such that a + b = b + a = 0
	typename std::set<ObType>::const_iterator beg(S.cbegin()), offend(S.cend());
	bool noProblemsYet(true), foundIdentity(false);
	ObType iden;
	for (typename std::set<ObType>::const_iterator ia = beg; ia != offend && noProblemsYet; ++ia)
		bool isIdentity = true;
		for (typename std::set<ObType>::const_iterator ib = beg; ib != offend && noProblemsYet; ++ib)
			// ---------- (1) --------------
			if (S.count(op(*ia, *ib)) == 0)
				noProblemsYet = false;
			// ---------- (3) --------------
			if (op(*ia, *ib) != op(*ib, *ia))
				isIdentity = false;
			for (typename std::set<ObType>::const_iterator ic = beg; ic != offend && noProblemsYet; ++ic)
				// ---------- (2) -------------
				if (op(op(*ia, *ib), *ic) != op(*ia, op(*ib, *ic)))
		if (isIdentity)
			foundIdentity = true;
			iden = *ia;
	if (noProblemsYet)
		if (!foundIdentity)
			bool foundInverse = false;
				if (op(*ia, *ib) == op(*ib, *ia) && op(*ia, *ib) == iden)
					foundInverse = true;
					break;
			// ---------- (4) -------------
			if (!foundInverse)
	return noProblemsYet;
/* ----------------------------- Functors --------------------------------------*/
template <typename T>
class Adder
	private:
		static const char symbol = '+';
	public:
		T operator() (const T & x, const T & y) { return x + y; };
		char getSymbol(void) { return symbol; };
class Subtracter
	private:
		static const char symbol = '-';
	public:
		T operator() (const T & x, const T & y) { return x - y; };
class Multiplier
	private:
		static const char symbol = '*';
	public:
		T operator() (const T & x, const T & y) { return x * y; };
class Divider
	private:
		static const char symbol = '/';
	public:
		T operator() (const T & x, const T & y) { return x / y; };
class Modder
	private:
		static const char symbol = '%';
	public:
		T operator() (const T & x, const T & y) { return x % y; };
int main()
	std::set<int> S1 = { 0, 1, -1 };
	std::set<int> S2 = { 0 };
	class Adder<int> p;
	std::cout << isGroup(S1, p);
	return 0;
Your test for an identity element is wrong. Your code if (op(*ia, *ib) != op(*ib, *ia)) { isIdentity = false; } clears isIdentity when the group operation is non-commutative. You should be checking whether op(*ia, *ib) != *ib.
Actually, shouldn't I be looking at
Code:
(op(*ia, *ib) != op(*ib, *ia) || op(*ib, *ia) != *ib)
Wikipedia's page (http://en.wikipedia.org/wiki/Group_(mathematics )) says the identity element must satisfy 0 + a = a + 0 = a.
