Can the Dot Product Determine Maximum Distance from the Origin?
  • Thread starter Thread starter jimmy42
    Max Vectors
3 replies · 2K views
jimmy42
Hello,
If I have a vector A and then I do the dot product on itself so A°A. Then can I use that to find the maximum distance from the origin? If I take the derivative of the dot product then can I know at what time the maximum distance was travelled?
I have done this but it is wrong based on the graph I made using Wolfram Alpha, I just need some reassurance that I'm on the right track.
hello jimmy42! :smile:
your method looks ok …
distance2 = A.A,
so if the distance is a maximum, then A'.A = 0
ie A' is perpendicular to A
Why if A'.A =0 is the distance a maximum?
I too have a question on this, and I'm failing to see why if the position vector and the velocity vector are perpendicular then the distance is a maximum if the above holds true.
Cheers in advance
Smithy
Welcome to PF!
Hi Smithy! Welcome to PF! :smile:
Because that's the derivative of the distance squared (divided by 2),
so it must be 0 if the distance squared is at a turning-point (maximum minimum or inflection point). :wink:
