Can the Energy of a Photon be Expressed in h/s?
  • Context: Undergrad
  • Thread starter Thread starter bobie
    Energy Photon
The discussion revolves around whether the energy of a photon can be expressed in the form of h/s, where h represents Planck's constant. Participants explore the implications of this expression, the units involved, and the relationships between energy, frequency, and time.
  • Some participants question the validity of expressing photon energy as h/s, suggesting that it mixes a constant with a unit, which is unusual.
  • Others argue that since Planck's constant h is in units of J·s, it cannot be directly modified to h/s without losing clarity in the expression of energy.
  • A participant proposes that energy can be expressed in terms of frequency, suggesting that E=hf implies a direct relationship between energy and frequency.
  • Some participants clarify that frequency (f) can be expressed as 1/T, leading to the equation E=h/T, which maintains consistency in units.
  • There is a suggestion to define a new unit of energy, termed "bobie," to simplify the relationship between energy and frequency, although this remains a hypothetical construct.
  • Discussions also touch on the nature of units and dimensions, with participants debating whether two different entities can share the same dimensions and the implications of mixing constants with units.
Participants do not reach a consensus on whether the expression h/s is valid. There are competing views on the interpretation of Planck's constant and its relationship to units of energy, leading to ongoing debate.
Participants express confusion regarding the distinction between physical constants and units, as well as the implications of mixing them in expressions. The discussion highlights the complexity of unit conversions and the need for clarity in mathematical expressions.
Science news on Phys.org
  • #62
Bandersnatch said:
It most definitely isn't. http://en.wikipedia.org/wiki/Fine-structure_constant#Definition Where did you get that idea from?
From your link:
The ratio of the velocity of the electron in the Bohr model of the atom to the speed of light. Hence the square of α is the ratio between the Hartree energy (27.2 eV = twice the Rydberg energy) and the electron rest mass (511 keV)
  • #63
I don't think you've read that carefully enough.
The ratio two velocities has no dimension, i.e. alpha is dimensionless
  • #64
Isn't 0.1 * 300,000c/s equal to 30,000 c/s?
  • #65
So?
The link says thatthe ratio of the velocity of the electron in the Bohr model of the atom to the speed of light
The velocity of the electron will have the dimension m/s
The speed of light has the dimension m/s
So if you divide one by the other you get a dimensionless number.
  • #66
DaleSpam said:
The relation is most definitely not biunivocal. I don't know why you would expect it to be. It isn't even univocal.
The point is that people tend to forget that. I think that Dimensions have their own identity like jars and boxes, but can also be , exactly like them, anonymous empty vessels: if you fill them with chocolates then
box*choc and jar*choc
is just the same (choc) and not two different entities, Is that right, Dalespam?, L2 is a scalar or an area?
In the other (G) thread (you know) I was frozen by posters who told me that "v2/ r is acceleration": everybody takes L/S2 as a fingerprint, nobody said" it might be acceleration, it is also acceleration" and I could not question that, starting an inappropriate discussion. It might be also something else, do you agree?
  • #67
yeah, v2/ r could represent some other concept or quantity than acceleration. The thing you can say for sure, is that quantity has the same dimensions as acceleration.
  • #68
f95toli said:
The speed of light has the dimension m/s.
Is every speed a fraction of C, since m= C*s/ 3*108?
10 m/s = 10 C*s/3*108*s
  • #69
No, in the context of the referenced discussion, v²/r was definitely acceleration (no "might" or "maybe"), specifically, it is the magnitude of the centripetal acceleration of a body in uniform circular orbit of speed v and radius r.
However, the dimensions of acceleration depends on the system of units you are using. If you are using SI (or indeed most systems of units) then acceleration has dimensions of L/T². In these units v has dimensions of L/T and r has dimensions of L, so v²/r has dimensions of (L/T)²/L -> L/T².
But if you are using geometrized units then acceleration has dimensions of 1/L. In these units v is dimensionless and r has dimensions of L, so v²/r has dimensions of (1)²/L -> 1/L. But in the absence of clarification of the system of units being used, generally SI is assumed.
  • · Replies 17 ·
