Can the tanker avoid hitting the reef with its engines back on?
  • Thread starter Thread starter ledhead86
    Laws Newton's laws
The discussion revolves around a physics problem involving an oil tanker that is at risk of hitting a reef due to engine failure. The tanker is initially moving towards the reef at a speed of 1.5 m/s and is 500 m away when the engines are restarted. The problem involves calculating the effects of acceleration produced by the engines against the motion towards the reef.
  • Participants discuss the calculation of acceleration using the formula a=Σ F/m and explore the implications of this acceleration on the tanker's motion. Questions arise about how to determine the time until the tanker stops and the distance it travels during this time.
Some participants have provided calculations for acceleration and are attempting to determine the time it takes for the tanker to stop. There is a mix of interpretations regarding the stopping distance and the conditions under which the tanker might hit the reef. The discussion includes varying opinions on the calculations and assumptions made about the motion of the tanker.
Participants are working under the assumption that the retarding force of water can be ignored, and there is some confusion regarding the final velocity and the conditions for stopping. The original poster's question about whether the tanker will hit the reef is central to the discussion.
ledhead86
An oil tanker's engines have broken down, and the wind is blowing the tanker straight toward a reef at a constant speed of 1.5 m/s. When the tanker is 500 m from the reef, the wind dies down just as the engineer gets the engines going again. The rudder is stuck, so the only choice is to try to accelerate straight backward away from the reef. The mass of the tanker and cargo is 3.6*10^7 kg, and the engines produce a net horizontal force of 8*10^4 N on the tanker.
Will the ship hit the reef? You can ignore the retarding force of the water on the tanker's hull.
Here is a diagram of the problem
http://image61.webshots.com/161/8/51/92/474485192tnwxrf_ph.jpg"
I know the acceleration would be -.0033333333 by the formula: a=Σ F/m
= 8*10^4 / 3.6*10^7.
Where do I go from here?
I reposted the question with a picture.
At what time does the tanker come to a stop?
Use that time to see how far it went.
I didn't know it came to a stop?
No, assume the reef isn't there when you calculate how long it takes the tanker to stop.
Then see how far it goes using the time you calculated. If D > 500 then it hits...
how do i do that?
The equation is V = a*t. You said a= -.0033. Also, you know you're traveling at 1.5m/s. So you want to know when your acceleration will get you to -1.5 m/s (so it will cancel out with the foward motion and you will stop).
the answer is YES, it will hit the reef
I found this thread while googling this same question, so I just wanted to add a few notes I found:
The acceleration is -2.22e-3, not sure how you got -3.33...
0 should be your final velocity, not -1.5. A negative acceleration, not velocity, will result in the boat eventually stopping. I got 506.7m for the total distance to stop, and my version of the problem asks what speed the boat hits at too: .17m/s for the velocity at which the boat hits the reef, which satisfies the hull's limit of .2m/s to maintain integrity.
-bf
11K
10K
18K
11K
