Can These Mathematical Sets Be Considered Subspaces?
mathmari
MHB
Hey! :o
We have the following subsets:
\begin{align*}&U_1:=\left \{\begin{pmatrix}x \\ y\end{pmatrix} \mid x^2+y^2\leq 4\right \} \subseteq \mathbb{R}^2\\ &U_2:=\left \{\begin{pmatrix}2a \\ -a\end{pmatrix} \mid a\in \mathbb{R}\right \} \subseteq \mathbb{R}^2 \\ &U_3:=\left \{\begin{pmatrix}x \\ y \\ z\end{pmatrix} \mid y=0\right \}\subseteq \mathbb{R}^3 \\ &U_4:=\left \{\begin{pmatrix}x \\ y \\ z\end{pmatrix} \mid y=1\right \}\subseteq \mathbb{R}^3\end{align*}
I want to sketch these sets and check in that way if these are subspaces. We have the following graphs:
  • $U_1$ :
    [DESMOS]advanced: {"version":7,"graph":{"squareAxes":false,"viewport":{"xmin":-5,"ymin":-5.5,"xmax":5,"ymax":5.5}},"expressions":{"list":[{"type":"expression","id":"graph1","color":"#2d70b3","latex":"x^{2\\ }+y^2\\ \\le\\ 4"}]}}[/DESMOS]
    This is a subspace, isn't it? But how can we explain that from the graph? (Wondering)
  • $U_2$ :
    [DESMOS]advanced: {"version":7,"graph":{"squareAxes":false,"viewport":{"xmin":-10,"ymin":-5.5,"xmax":10,"ymax":5.5}},"expressions":{"list":[{"type":"expression","id":"graph1","color":"#2d70b3","latex":"x=-2y"}]}}[/DESMOS]
    Since this line goes through the origin, it is a subspace, or not? (Wondering)
  • This is the $xz$ plane with $y=0$.
    This is a subspace, since the zero vector is contained, or not? (Wondering)
  • This is the $xz$ plane with $y=1$.
    This is not a subspace since the zero vector is not contained. Is that correct? (Wondering)
mathmari said:
Hey! :o
  • $U_1$ :
  • $U_2$ :
Your graph for the first one looks odd because your graph does not have the same size units on the two axes. The graph should be a circle, not an ellipse. As for "subspace", are you clear on what a subspace is? If u and v are in the space then u+ v and au, for a any number, must be in the space.
For the first one, u= (2, 0) is in the space but 2(2, 0)= (4, 0) is not.
For the second one we can write u= (2a, -a) and v= (2b, -b). Then u+ v= (2a+ 2b, -a- b)= (2(a+ b), -(a+ b)) so is also in the set. And for any number, x, x(2a, -a)= (2(xa), -(xa)) so is in the set. Yes, the origin, (0, 0)= (2(0), -0) is in the set. Geometrically a subspace of R2 is a line through the origin. The first example was not a line.
Yes, the third is the xz-plane. In R3, any subspace is either a line containing the origin or a plane containing the origin. This is a plane containing the origin. A proof that this is a subspace would be to take two such vectors as u= (a, 0, b) and v= (c, 0, d). Then u+ v= (a+c, 0, b+ d) which is in the set and, for x any number, xu= (xa, 0, xb), in the set.
Strictly speaking the last one is NOT "the xz-plane with y= 1". The "xz-plane" always has y= 0. This is a plane parallel to the xz-plane. You are right that this is not a subspace because it does not contain the origin. More specifically, u= (a, 1, b) is in the set but 2u= (2a, 2, 2b) is not.
You seem to be under that impression that a set is a subspace as long as it contains the origin. That is "necessary" condition, but is not "sufficient". A subspace of R2 must be a line containing the origin and a subspace of R3 must be a line or plane containing the origin.
