kurious
- 633
- 0
Would three galaxies, held together by dark matter, be an example of a three body problem?
Galaxies have so many bodies that they can probably be treated as a fluid dynamical problem of the non-ideal gas variety: gravity being analogous to VanderWaals forces.selfAdjoint said:No, because they are too loose constructed. The Sun, Earth, and Moon are a good three body problem. Galaxies are a many body problem.
I wonder how many more schools exist down there? The University of Hell, Brimstone Technical School...Chronos said:The classic 3 body problem is the homework equivalent of violating the Geneva convention. Solving it for 3 galaxies is a physics 101 assignment at Hades University.
Jenab said:gravity being analogous to VanderWaals forces.
Jerry Abbott
tony873004 said:I know there is no solution to the 3-body problem except numeric integration. But does this just mean nobody has found the solution yet? I know many prominent mathimaticians from years ago tried to solve it. Were they wasting their time? Has it been proven that the 3-body problem has no solution? Or is it possible that I might wake tommorow to find on page 9 of my newspaper "Mathamatician solves 3-body problem".
But a computer doing this as a repetitive task is an example on a numerical integration. And numerical integrations are subject to truncation errors (if you make the time step too fast) and round-off errors.BobG said:Yes, people have solved it...
...Others can get much more difficult to do by hand, since your angles and distances are always changing, but not so much so for a computer which can do repetitive tasks very well.
I might be wrong, but I think the 2-body is also analytically solveable even if both bodies have significant mass. They would both be tracing perfect unperturbed ellipses around their barycenter. A 3rd body introduces pertubations and messes the whole thing up.enigma said:Numerically only. There aren't enough constants to solve it analytically.
The only reason we're able to solve the 2 body problem analytically is because you can make the assumption that 'body 2's mass' << 'body 1's mass'.
As long as you have more than 2 bodies, and 2 of your bodies have mass, then you have an n-body problem. In certain instances, you can treat an n-body problem like a bunch of 2 body problems and get good results, but they'll just be approximations. So a galaxy can not be considered a body because it is many bodies.Rothiemurchus said:If one of the bodies in a three body problem has a large mass - like a galaxy -
and this mass is in reality made of many masses,what determines when two much smaller masses become part of the many body probelm that the galaxy already is in its own right? Where is the borderline?
tony873004 said:I might be wrong, but I think the 2-body is also analytically solveable even if both bodies have significant mass. They would both be tracing perfect unperturbed ellipses around their barycenter. A 3rd body introduces pertubations and messes the whole thing up.
But do you know if a 3-body analytical solution is an impossiblilty, or just a solution that nobody's discovered yet?
Have you submitted your solution for publication in a peer-reviewed journal?khavel said:You can download my new e-book 'N Bodies - No Problem' at:
http://www.grevytpress.com/model.html
You can also try there n-body simulations (all done by the same program).
Unless I misunderstand you, you are wrong. all that is required for the analytic solution of any "central -force" two-body problem is to convert it to a one body problem with a fixed center (At old center of mass), and the one body with "reduced mass" equal to mM/(m+M). The potential can have any form (power) you like. Check out any high level classical mechanic book - perhaps even a google search on {"reduced mass" AND "central force"} will show you this.Haelfix said:Already the two body general solution is a horrendous chore to do, and took the work of many famous physicists to solve completely (for the case of a 1/r potential). Unfortunately the integral form is nasty (elliptical integrals), but they have been done.
Change the potential, and you can no longer get a closed form stable solution...
