Mentor
- 50,928
- 26,973
Ok.villy said:I mean the point on the wordline of B that appears to be simultaneous with Aa1, from the perspective of A.
This is a huge increase in complication, because the two Lorentz boosts in question--from A's rest frame to B's rest frame, and from A's rest frame to C's rest frame--are in different directions. That means the transformation from B's rest frame to C's rest frame, or vice versa, is not a pure Lorentz boost; it's a boost plus a spatial rotation. I doubt that anyone's powers of visualization are up to handling that by intuition. Cases like this need to be worked by grinding through the math. But as @Dale has pointed out, before even trying that, you need to be sure you have a firm grasp of the simple 2D (1D space + time) case.villy said:As for the diagram, I am picturing it, it's just that it requires 2 dimensions for space
You can at least get a start on the 3D (2D space + time) case by looking at the two obvious edge cases, though: the case where B and C are moving in the same direction (in which case they are at rest relative to each other--easy), and the case where B and C are moving in opposite directions, in which case the relative speed between B and C can be obtained from the simple relativistic velocity addition formula.
As I understand things, you are specifying that the objects always move inertially, correct? If that is the case, then yes, all of the lines of interest will be straight lines.villy said:It is all straight lines though, right?
