something_about
- Messages
- 27
- Reaction score
- 0
hi
1-I'm not shure that it is possible for two objects A and B to exert force on each other, with A exerting 5 N and B exerting 9 N at the same time. If it is, then due to Newton's third law A will also exert reactionary force -9 N back on B and B will exert reactionary force -5 N back on A.
So will resultant force on object A be 9 N and on B also 9 N?
2-Two objects with
m1 = 2000000 kg
m2 = 4 kg
are connected with rope. We pull object m2 with force F = 2000000 N.
F = ( m1 + m2 )*a - > a = F/( m1 + m2 ) = 1 m/S^2
If we threat m1 and m2 as separate systems, then F1 + F2 = F .
Net force on object m2 is F2 = F - F1 = 4N and net force on object m1 is F1.
But even if net force on m2 is 4N, we still pulled on m2 with force F. Considering that, does m2 experience all the destructive effects of being pulled with 2*10^6 N, or would damage on m2 be no greater than if it was pulled on pulled by F2 ( and m1 was wasn't connected to it with a rope )?
3-The following always confused me. If two forces(each 10^6 N) are exerted on a person, one from left and other from right, then resultant force is zero. But even if net force is zero, the two forces would cause a lot of damage to that person.
Well how is that different from air pressure where air puts pressure of 10^5 N/m^2 on your skin and there is equal pressure exerted on your skin from opposite direction?
Why doesn't skin get damaged from being pressed by such two large forces? How are the two examples different?
thank you
2-Two objects with
m1 = 2000000 kg
m2 = 4 kg
thank you
