Can we achieve linear time with groups of 7 in the SELECT algorithm?
  • Context:
  • Thread starter Thread starter evinda
    Linear Time
4 replies · 2K views
evinda
MHB
Hello! (Wave)
The [m]SELECT[/m] algorithm determines the $i$th smallest element of an input array of $n>1$
distinct elements by executing the following steps.
  • 1. Divide the $n$ elements of the input array into $\lfloor \frac{n}{5} \rfloor $ groups of $5$ elements each and at most one group made up of the remaining $n \mod 5$ elements.
    2. Find the median of each of the $\lfloor \frac{n}{5} \rfloor $ groups by first insertion-sorting the elements
    of each group (of which there are at most $5$) and then picking the median
    from the sorted list of group elements.
    3. Use SELECT recursively to find the median $x$ of the $\lfloor \frac{n}{5} \rfloor $ medians found in step $2$. (If there are an even number of medians, then by our convention, $x$ is the lower median.)
    4. Partition the input array around the median-of-medians $x$ using the modified
    version of PARTITION. Let $k$ be one more than the number of elements on the
    low side of the partition, so that $x$ is the $k$th smallest element and there are $n-$k
    elements on the high side of the partition.
    5. If $i=k$, then return $x$. Otherwise, use SELECT recursively to find the $i$th
    smallest element on the low side if $i<k$, or the $i-k$ th smallest element on
    the high side if $i>k$.
At the algorithm [m]SELECT[/m], the input elements are divided into groups of $5$.
Can the algorithm achieve linear execution time if the elements get divided into groups of $7$?
Show that if groups of $3$ are used , linear execution time cannot be achieved.
How can we deduce if the algorithm can achieve linear execution time if the elements get divided into groups of $7$? (Thinking)
We could find a recurrence relation that describes the algorithm, right? (Thinking)
Could you help me to find the time complexity of each of the steps?
Do you understand the proof when the length is divided by 5 ?
I saw that for the second step, the cost should be $c \cdot \lceil \frac{n}{5} \rceil$. How can this be the cost, although we apply Insertion sort? Also how can we find the cost for the step $5$? :confused:
The insertion sort is done on lists with fixed length equal to 5 , right ?
