Can we construct a Lie algebra from the squares of SU(1,1)
The discussion revolves around the possibility of constructing a Lie algebra from the squares of operators in the SU(1,1) algebra, particularly in the context of quantum optics. Participants explore the implications of using squared operators and their commutation relations, as well as the relationship between these operators and existing algebraic structures.
  • One participant discusses decomposing exponential operators from the SU(1,1) algebra and questions the feasibility of constructing an algebra from squared operators like \(K_+^2\) and \(K_-^2\).
  • Another participant argues that normal products, such as squares, generally violate the Jacobi identity, suggesting that while one can form a Lie algebra from an associative algebra, the squares alone do not suffice without additional structure.
  • A participant proposes that if one considers products like \(K_+^2\) and \(K_-^2\) as new basis elements, it could lead to an infinite-dimensional Lie algebra generated by these products.
  • One participant introduces the concept of a finite algebra formed from squares of operators, referencing a simple algebra with commutation relations leading to a group structure, but seeks generalizations of this idea.
  • Another participant questions the terminology of "group" in this context, suggesting that the discussion is more about algebras and the need for clear definitions of commutation relations for the proposed elements.
  • Further clarification is provided regarding the context of bosonic mode operators and their relation to the Heisenberg algebra, emphasizing that squares do not equal the identity operator.
  • There is a discussion about the representation of finite-dimensional complex Lie algebras as matrix algebras and the implications for defining commutation relations involving the identity operator.
  • One participant expresses confusion about the definitions and operations involved, indicating a need for clarity in the algebraic structure being discussed.
Participants express differing views on the feasibility of constructing a Lie algebra from squared operators, with some proposing methods to do so while others challenge the validity of these approaches. The discussion remains unresolved regarding the specific definitions and structures necessary for such constructions.
Participants highlight limitations in defining commutation relations and the properties of the operators involved, particularly in distinguishing between associative and Lie algebras. There is also an emphasis on the need for clear definitions to avoid ambiguity in the discussion.
Buddha_the_Scientist
I am trying to decompose some exponential operators in quantum optics. The interesting thing is that the operators includes operators from Su(1,1) algebra $$ [K_+,K_-]=-2K_z \quad,\quad [K_z,K_\pm]=\pm K_\pm.$$
For example this one: $$ (K_++K_-)^2.$$ But as you can see they are squares of it.
I wonder if it is possible to construct algebra for such operators for example an algebra includes $$K_+^2, K_-^2,...$$ I tried, it doesn't seem possible but still wanted to ask. There exists many operators in a similar fashion. Up to now I could only resort to approximation techniques. The operators are bosonic mode operators so squares aren't equal to identity.
A normal (say e.g. associative) algebra product as the square is, usually (unless it is trivially zero) breaches the Jacobi identity, so the answer in general is no. But for every associative algebra, the setting ##[X,Y]:=XY-YX## gives you a Lie algerbra, but this requires an associative multiplication first. Another possibility is, to systematically add all needed products as new basis elements. E.g. in your example we have
(K_++K_-)^2 = K_+^2 +K_+K_-+K_-K_++K_-^2
and we can consider all these new products as new basis vectors: ##B_1=K_+,B_2=K_-,B_3=K_+^2,B_4=K_+K_-,B_5=K_-K_+,B_6=K_-^2## and so on. Without any properties about finiteness, esp. for the mixed products, we will get an infinite dimensional Lie algebra, freely generated by those products.
The main difficulty is, that the normal products alone don't belong to the Lie algebra anymore, they have to be artificially added. E.g. if we look at matrices with trivial trace, which form a Lie algebra, this property doesn't hold any longer for their products:
\begin{bmatrix}0&1\\0&0\end{bmatrix}\cdot \begin{bmatrix}0&0\\1&0\end{bmatrix} = \begin{bmatrix}1&0\\0&0\end{bmatrix}
The reason is, as already mentioned, the Jacobi Identity. This is basically the product or Leibniz rule of differentiation:
\operatorname{ad}([X,Y])=[\operatorname{ad}(X),\operatorname{ad}(Y)]=\operatorname{ad}(X)\circ \operatorname{ad}(Y) - \operatorname{ad}(Y) \circ \operatorname{ad}(X)
with the Lie multiplication ##\operatorname{ad}\, : \,Z \mapsto [X,Z]\,##.
Thank you for the reply. My point was if it is possible to construct a finite algebra easily from the squares of operators that constitutes a finite Lie algebra already. For example consider the following algebra:
$$[L_1,L_2]=I$$
Where I represents identity. Now basically these operators form a group:
$$ L_1, L_2, I$$
Now if we take squares and check the commutation relations we see that:
$$L_1^2, L_2^2, (L_1L_2+L_2L_1)$$
also form a group. The first group is sort of simple because of the identity operator, but I was wondering if there are generalizations for these sort of constructions.
Not sure what you mean by group in this context. It looks more as if we're still talking about algebras.
$$[L_1,L_2]=I$$
$$ L_1, L_2, I$$
This is the smallest Heisenberg algebra. It can be represented by ##(3\times 3)-##matrices with ##L_1=\delta_{12}\, , \,L_2=\delta_{23}\; , \;I=\delta_{13}\,.##
With the representation above, we have ##L_1^2=L_2^2=L_2L_1=0## and ##L_2L_1=I\,.## So in case you meant something different, you'll have to define it completely. It is not clear what ##[X,Y]## should be for ##X,Y \in \{L_1^2, L_2^2, (L_1L_2+L_2L_1)\} \cup \{L_1,L_2,I\}##not to mention even more general elements as e.g. ##L_1^{n_1}L_2^{n_2}L_1^{n_3}L_2^{n_4} \ldots ## and so on.
As I noted in my first post I am talking about bosonic mode operators, not matrices, the squares doesn't equal to I. Consider the annihilation and creation operators:
$$a,a^{\dagger}$$
Now they constitutes the Heisenberg algebra and as I pointed in my post:
$$a^2,a^{\dagger^2},a^{\dagger} a+aa^{\dagger}$$
also constitutes a group. This is the SU(2) group.
That's what I meant.
$$a,a^{\dagger}$$
Every finite dimensional complex Lie algebra can be viewed as a matrix algebra. (Ado)
Whether it is represented by ##I=\sum \delta_{ii}## or not is irrelevant. You haven't defined what ##[L_i,I]## should have been, so I assumed ##[L_i,I]=0## because what you have given was incomplete to define a Lie algebra. The representation of a Heisenberg algebra by the maximal nilpotent subalgebra of ##\mathfrak{gl}_3## is the standard representation. And it is what it says: a representation by choosing basis vectors and defining a multiplication table. ##I=\delta_{13}## satisfies the definition, what it looks like doesn't matter. If you meant ##[L_i,I]=L_i## instead, you should have mentioned, as usually the identity commutates with all other operators. With this new definition we basically get ##\mathfrak{sl_2}\cong \mathfrak{su}_2##. Neither of them contains elements as ##L_i^2##
In a group, you have one operation, which you can either write as multiplication or addition, but not both. Furthermore, I don't see any inverses here. So what we really have is an algebra, but in this case, the question is: which one? This means, can you write down a complete basis for the underlying vector space, whether it is an operator space or not, and the multiplication table for this algebra? Both is needed to determine, what it is. If you insist on a basis ##\{A,B,I,A^2,B^2,AB+BA\}## chances are that it is neither an associative nor a Lie algebra, but I don't want to guess all possible multiplication tables. In any case, it is never a group.
Ok, sorry for my ignorance.
  • · Replies 32 ·
  • · Replies 26 ·
  • Poll Poll
