OCR
- 995
- 936
The discussion revolves around the feasibility and methods of turning a cube on a lathe, exploring various machining techniques and setups. Participants share insights on the practicality of this task, as well as comparisons to machining other shapes like spheres, with references to videos and personal experiences.
Participants express differing views on the practicality and methods of turning a cube on a lathe, with no consensus reached on the best approach or the seriousness of the topic.
The discussion includes various assumptions about the capabilities of lathes and milling machines, as well as the definitions of machining processes, which remain unresolved.
Yes.OCR said:Can you. . .
Turn a CUBE on a LATHE?!
Not sure if Baluncore is deadpan riffing on joke, orBaluncore said:Yes.
But...
Repeatably, again and again.DaveC426913 said:What I saw was: A lathe. With a cube on it. Being turned.
Thought so.Baluncore said:How could I miss the opportunity to deliver deadpan,
Yes, we know.wirenut said:Yes, it is possible. See "machining a cube on a lathe" by machiningmomentsbrad on youtube.
But it is very easy to turn a ball on the bed of a vertical milling machine.sophiecentaur said:It’s not as convenient to produce a ball on a vertical milling machine.
A ball or a cube can be produced pretty much anywhere a magician turns up to remove the cover.wirenut said:Yes, it is possible. See "machining a cube on a lathe" by machiningmomentsbrad on youtube.
A tow ball can be made in one setting.DaveC426913 said:Machining a ball on a milling machine is functionally identical to machining a cube on a milling machine, except the number of remountings required is somewhat larger.
In actual practice, you can’t cut a full sphere in one setup. You still have to hold the part and rotate it somehow. To produce a full sphere, you must use two separate holding setups.
