Can't figure out solution -- Space probe with engine thrust vectors
22 replies · 5K views · last reply
Ben5386
A space probe has two engines. Each generates the same amount of force when fired, and the directions of these forces can be independently adjusted. When the engines are fired simultaneously and each applies its force in the same direction, the probe, starting from rest, takes 25 s to travel a certain distance. How long does it take to travel the same distance, again starting from rest, if the engines are fired simultaneously and the forces that they apply to the probe are perpendicular?
V0=0
t1=25
D=V0t+1/2at^2
a=2T/m
D= 0*t+1/2(2T/m)*25^2
D=(T/m)*25^2
V0=0
t1=25
D=V0t+1/2at^2
a=2T/m
3. The Attempt at a Solution
D=(T/m)*25^2
Welcome to the PF.
You will need to use vectors to figure this out (or at least express the thrusts and distances in two dimensions). Can you draw two diagrams for the vector thrusts involved?
Welcome to the PF.
How do I draw the force vectors on this site I have them on paper
If you can take a good picture of them (clear, bright, not fuzzy, etc.), you can use the UPLOAD button in the reply window to upload a JPG file from your PC or laptop. :smile:
Here they are the upside down T is the perpendicular vector with the F in the middle and parallel are the ones are below.
  • Handwritten diagram of two force vector sets: top, a symbol with three arrows fanning out from a point, one labelled F pointing right; bottom, a dot with two parallel arrows labelled F pointing right.
So what is the magnitude of the resultant force for the 2nd case? What is the ratio of the forces for the first and second case? What equation would you then use to figure out the ratio of the times it takes to travel a certain distance?
I think it is pythagorean theorem for the magnitude of the resultant force of the second case. To solve for the distance I would use the equation D=Vo+1/2at^2 and since the distance is the same I can plug in the distance for the second case
You are on the right track. Use the fact that Vo=0 to help simplify that equation, so you can take ratios.
Also, on your diagram, re-label the right-angle drawing with each of the two right-angle forces being "F", and the middle resultant will then be what by the Pythagorean theorem?
The Magnitude of the vector in the middle labeled M in the picture
  • Handwritten sketch on lined paper of a vector diagram: two equal force vectors labeled F point up-left and down-left from a common point, with their resultant labeled M pointing right, plus a parallelogram of dashed construction lines; below, a line labeled Pa shows two parallel arrows both labeled F pointing right.
So in the first case, M=2F. What is M in the second case? What does that give you for the ratio of the two times to go the same distance? What does that give you for the 2nd time? You're almost done! :smile:
I have D=1/2(2T/m)*t^2 which reduces down to D=(F/m)*t^2 and for the second case is M equal to F?
No, M for the second case is not F. It is more than F and less than 2F. Look at your diagram and use the square you drew with F as each side and M on the diagonal (hypotenuse of the 2 triangles...).
Would it be F/M meaning the cosine of 45 degrees
I'm not sure what you mean.
If you have a right triangle with two sides of length 1, what is the length of the hypotenuse?
I have to bail for a couple of hours. You are very close to solving this. I'll check back in later tonight to be sure you got the right answer. :smile:
Would it be the square root of 2F
Written more precisely, yes it would be F√2.
So finish it off now (if you haven't already). What is the ratio of the times? What is the time for the second scenario?
I know that this answer is probably wrong but is it 84.089
Please don't make me do extra work :smile: Please show your detailed work with units included. Thanks.
I have the ratio of the two and I have 2F/F
I have the ratio of 2F/F(sqrt(2)) which reduces to the sqrt(2) sorry my computer doesn't show me the mathematical functions. so I put in what I got for distance earlier which is (F/m)*t^2=1/2*sqrt(2)*t^2
That doesn't help. Show your work with units included.
I don't know how but I got it the answer is 29.73 seconds.
Thanks so much for your help :)
