Can't understand integral limits in question
  • Thread starter Thread starter sa1988
    Integral Limits
8 replies · 2K views · last reply
sa1988
Just a quick one - Have I deciphered the wording of this question properly?
All necessary info is in the embedded image.
To me the limits describe a typical 'pyramid in the corner', but the fact it's an integral over the function 'x' is confusing me. Do I just go with it and generate an answer at the end?
That's going to be difficult, because when integrating over x you don't know the upper bound !
Pyramid in the corner is the picture I get too. I have even sketched it. I notice that when x is known, I know what the integral over the other two represents.
If you want to write the integral properly, it would be a good thing to distinguish between bounds and integration variables. Much clearer. ([edit] In this case not necessary, I realize)
Well the integral I wrote does come out with a numerical solution. I just don't know if I wrote the correct integral or not. :confused:
Ah, I see. You are quite right.
However, if you pick an x, ànd a y, you can easily integrate over z: ##\int_{z=0}^{1-x-y} dz## yielding a simpler expression. Then over y (yielding a triangle area) then finally over x.
So, :redface: my nitwit "distinguish" comment is superfluous and I nitwittedly wanted to improve on an integral expression that wasn't wrong in the first place.
Hmm, I can't see a major world of difference between my ##\int_{x=0}^{1-z-y} dx## and your ##\int_{z=0}^{1-x-y} dz## ?
Ah well, as long as I was correct with my interpretation of the question, and as long as it came to a good answer, I'm happy!
Edit: Oh wait I see it now. If I save the dx integral till last, I'll have far less algebraic havoc to deal with as I go through. Great, all understood, cheers!
You mean ##\int_{x=0}^{1-z-y} {\bf x}\, dx## ?
We agree it's the same thing, but I liked to write it as
$$ I = \int_{x=0}^1\, x\, \left ( \int_{y=0}^{1-x} \left ( \int_{z=0}^{1-x-y} dz \right ) dy \right ) dx =\int_{x=0}^1\, x\, \left ( \int_{y=0}^{1-x} 1-x-y \ dy \right ) dx = \int_{x=0}^1\, x\, \left ({1\over 2}(1-x)^2\right )\, dx $$I ended up with 5/24, and you ?
Ah yeah that's what I meant, sorry I left out the x .
Hmm I get 1/24? I've punched it into mathematica a few different ways and get the same answer with that too.
Roles have reversed! You correctly correct my 5/24. It should be 1/24.
Time to move on to the next exercise...
Haha, fantastic. Well my main issue was understanding the limits set out in the question, and it turns out everything was ok in the end. Solving it was just a bonus. Thanks!
Oh and I looked back at the method I set out in the original post, and I don't even know why I had the limits set up that way around. Ok it worked but taking dz first should have been obvious! Ah well, living and learning.
