Carbon at very low temperatures
  • Level: Graduate
  • Thread starter Thread starter RichPeterson
    Carbon
12 replies · 4K views · last reply
RichPeterson
Has study or experimentation been done on chemically and isotopically pure carbon at very low temperatures? Thanks, Rich Peterson
Probably - most things have.
It has a useful engineering property. It's thermal conductivity drops suddenly below about 15K. You use it as a thermal short on liquid Helium cooled instruments, it gives you a thermal path to get the cold in during pre-cooling but then 'disconnects' to give good insulation once you are cold.
Moreover, charcoal sorption pumps are routinely used to get to temperatures below 1K. Adsorption energies and kinetics for different elements/compounds at various temperatures would definitely have been well studied. At temperatures above 1K, carbon-glass RTDs are widely used for thermometry in magnetic fields. Lots of good reasons to study carbon at low temperatures.
But as mgb said above, it doesn't matter that there be reasons - it would have been studied nevertheless.
In laser spectroscopy, crystals emit shorter bandwidths at very low temperatures. So their radiation has sharper peaks. Carbon might have similar properties if it has any spectroscopic use.
How is this different from garden variety thermal broadening that is seen in virtually every spectrum of any material?
I am not sure, since I studied the laser crystals many years ago. We cooled them to liquid Helium temperatures, and just noticed the emission peaks became very sharp.
We would use the 514nm Argon, and the crystals would emit in the IR. We weren't interested in the broadening, but more the narrowing of the emission cross-section.
Unless I'm misunderstanding you completely, this is perfectly natural behavior that is not characteristic of your specific material. Take a look at the temperature dependence of any photoluminescence spectrum, or x-ray diffraction/fluorescence spectra, or spin resonance spectra, etc.
somewhere i read carbon conducts electricity at some specific temperature...is it true?
Yep, different forms of pure carbon also exhibit different properties of conductivity. Specifically, graphite is a good conductor, which becomes even better when made into different structures such as fullerines. Diamond is a good insulator unless mixxed in with some other element (such as blue diamond, a semiconductor).
A quick word as to why, graphite is sp2 hybridized which allows for the movement of electrons, while diamond is sp3. The pi bond is graphite covers multiple atoms and allows for delocalization of electrons. I won't go into too much detail, since this information is something I'd expect you can find in lots of introductory books on quantum mechanics or nanotechnology.
Lots of work is being done on superconductivity in carbon nanostructures, a quick search on arxiv and you can probably find some of the more interesting papers and something a bit more advanced. Will post more on this subject when I have more time.
hi thanks..for making me to remember these nice details..
It's cool, sometimes the simplest stuff is the easiest to forget :redface:
I often forget to put on my shoes before going to work :P
