Cartesian Vector Form - Door with 2 Chains
14 replies · 3K views
BuckBee
[/B]
The door is held open by the means of 2 chains. If the tension in AB and CD is Fa = 300 N and Fc = 250 N, respectively, express each of these in Cartesian Vector Form
Sin / cos / tan
The angle of FA at B is atan(1.5sin30/(1+1.5cos30 )) then +y direction force A is 300cos that angle and -z direction force is 300sin that angle
There are 2 forces in 2D but I don't understand the 3D. There are 3 forces x, y and z
See Image Attached
Take it in stages. Drop a vertical from C to a point G below it on the ground. The tension has a vertical component and a horizontal one from G to D.
Thanks but I am still a bit confused with the (x) force. I am really not sure about the 3D calculations. The horizontal length for C to D is 2 meters with a Fc of 200N
+y direction force is tan(1.5sin30/(1+1.5cos30) = X then 300 CosX
-z direction force is tan(1.5sin30/(1+1.5cos30) = X then 300 SinX
No, that's just the X component. What is the whole horizontal distance? Hence what is tan(∠CDG)?
ok I admit I have no idea how to do the 3D x, y, z forces for CD. I have no idea what formula to use or where to start
The 2D y, z forces for AB I understand that, see the calculations in the image attached below, I am sure that's correct
C, D, G lie in a vertical plane. That's just 2D.
Use Pythagoras to find the distance DG, hence find ∠CDG.
cool thanks but we don't know the distance DC to find out the length DG using Pythagoras
So does that look correct? If so I can then work out the x, y, z forces. Also how do I express the answer in cartesian vector form?
Yes, that's it. You might want to keep one more digit of precision during the calculation... I have 3.14 where you have 3.1.
Cartesian vector form probably means as three numbers in parentheses: (Fx, Fy, Fz).
Great, thanks for the help, I think I've got it now. Can you please double check the calculations and answers and let me know if correct, Cheers
I'm getting rather different numbers. Where does the 2.23 come from? 1+0.75(√3)/2=2.3.
But you've basically cracked it, so I'll show you an easier way. You do not need to calculate the angles in degrees.
In 2D, the components of a unit force in the direction (x,y) are x/h, y/h where h=√(x2+y2), right?
In 3D, that extends simply to x/h, y/h, z/h where h=√(x2+y2+z2).
