Cat and mouse kinetic energy with same speed
9 replies · 5K views · last reply
Tyrannosaurus_
A cat is chasing a mouse in a straight line. The cat's mass, mc, = 5.0kg. The mouse's mass, mm, is 0.035kg.
Problem 1. If the kinetic energy of the cat is 100 times the kinetic energy of the mouse can the cat catch the mouse?
Problem 2. If the cat and the mouse have the same speed, what is the kinetic energy of the cat?
Conservation of energy. Kinetic energy = (1/2)mv2
Solution for Problem 1.
Ekc = (100)Ekm
(1/2)mcvc2 = (100)(1/2)mmvm2
mcvc2 = (100)mmvm2
vc2 = [(100)mmvm2] / mc
vc2 = [ (100)(0.035kg)vm2 ] / 5.0kg
vc2 = (7/10) vm2
vc = (7/10)(1/2) vm
vc ≅ 0.83 vm
Therefore, the cat cannot catch the mouse. The cat's speed is 83% of the mouse's speed
{Is the result correct? Is my therefore statement correct? Is this the proper interpretation of the result?}
Solution for Problem 2. - If the speed of the cat is the speed of the mouse what is the cat's kinetic energy?
vc = vm
[(2Ekc)/mc](1/2) = [(2Ekm)/mm](1/2)
Ekc/mc = Ekm/mm
Ekc = mc Ekm / mm
Ekc = {mc (1/2mmvm2)} / mm
Ekc = (1/2) mcvm2
Ekc = 2.5kg vm2
Ekc = How can I find this value? All of the known problem info. is stated.
The correct answer according the answer page of the text is "140 times."
What approach should I take to solving this problem.
Many thanks!
For the second problem why don't you express the velocities as the same variable and then solve for Ec
Is your suggestion different from how I started the solution? vc = vm I do not understand your suggestion.
vc = vm
Ekc/mc = Ekm/mm
You have the answer here! Just plug in the values for m and solve for E cat!
Ekc is 2.5 * "speed of mouse" squared. What do i use for the speed of the mouse?
rpthomps said:
vc = vm
Ekc/mc = Ekm/mm
Ekc = mc Ekm / mm
Look at the last line of the expression I just quoted, that you generated. Do you see velocity there?
The kinetic energy of the mouse, Ekm, is unknown! The velocity of the mouse is unknown! Only the mass of each body is known!
Clearly you're far too brilliant for me! What is the value of Ekc?
Ek_cat=(m_cat/m_mouse)xEk_mouse
Ek_cat=(5/0.035)xEk_mouse
Ek_cat = 140xEk_mouse
So, like I said, "how do I find the value?"
Thanks for your effort. In the future, save both of our time by confirming my solution. Ek cat is unknown! It might be expressed in terms of Ek mouse, but Ek cat's value is, like I asked, not possible to be found.
Wow. I wasn't expecting that response. I wasn't trying to save you time. I was trying to help you get to the answer yourself, which is infinitely more valuable than having me just solve the question myself or just confirming your answer. The solution that you yourself indicated is not in itself a value but rather a multiplication of another one. You said the answer was 140 times! 140 times what? Well, 140 times the kinetic energy of the mouse. It is impossible to find the value of the cat's KE given the information of the question.
In the future, don't lambast people who are trying to help you.
