Centre of gravity, moment of inertia and radius of gyration
The discussion focuses on calculating the center of gravity, moment of inertia (MOI), and radius of gyration for composite shapes, specifically a rectangle and a triangle. Key formulas include the center of gravity equation X = (m1x1 - m2x2) / (m1 - m2), the moment of inertia for a rectangle Ixx = (1/3)ml², and for a triangle Ixx = (1/18)md². The radius of gyration is derived from Ixx = mk². The participants clarify the correct application of these formulas, particularly the placement of axes and the use of the parallel axis theorem.
  • Understanding of basic mechanics principles, specifically center of gravity and moment of inertia.
  • Familiarity with composite shapes in physics and engineering.
  • Knowledge of the parallel axis theorem for calculating moment of inertia.
  • Ability to perform calculations involving mass, distance, and geometry.
  • Study the application of the parallel axis theorem in moment of inertia calculations.
  • Learn about the derivation and application of the center of gravity for composite shapes.
  • Explore advanced topics in mechanics, such as dynamic stability and rotational motion.
  • Investigate the differences between calculating moment of inertia about different axes for various shapes.
Students in mechanical engineering, physics enthusiasts, and professionals involved in structural analysis or design who require a solid understanding of center of gravity, moment of inertia, and radius of gyration calculations.
DevonZA
Centre of gravity: X=m1x1-m2x2/m1-m2
MOI rectangle: 1/3ml^2
MOI triangle: 1/18md^2
Radius of gyration: Ixx=mk^2
Mass of body 1: b*l*p = 0.8*1*10=8kg
Mass of body 2: 1/2b*h*p = 1/2(0.4)*0.6*10=1.2kg1.1
X=m1x1-m2x2/m1-m2
= 8*(-400)-1.2*(-1000/3)/8-1.2
= -411.7mm
1.2
Ixx= 1/3ml^2 - 1/18md^2
= 1/3*8*1^2 - 1/18*1.2*0.2^2
=2.664m^4
1.3
Ixx=mk^2
2.664=(8-1.2)*k^2
k=625.91mm
How do you get 400, why -400, and how do you get 1000/3?
That should be 500, from the centre of the rectangle to the XX axis is 500mm.
I believe the centre of the triangle should be 2/3*600 = 400mm
Then added to the 200mm from the start of the triangle to the XX axis should give 400+200=600mm.
I put a negative in front of the 400 and 1000/3 as they are "away" from the XX axis.
I don't know why I put 1000/3, I think I was dividing the length of the rectangle in 3 because of the triangle for some reason.
X=m1x1-m2x2/m1-m2
= 8*(-500)-1.2*(-600)/8-1.2
= -482.35mm
Right.
But they are "away" from that axis in the positive y direction.
haruspex said:
Right.
Meaning they should be positive?
If they were below the X axis then they would be negative? In other words if the XX axis were at the top of the rectangle.
Yes.
Okay so then
X=m1x1-m2x2/m1-m2
= 8*(500)-1.2*(600)/8-1.2
= 482.35mm
Is this correct?
What about my answers for 1.2 and 1.3?
The term for the triangle is wrong. What axis would be right for that expression?
The formulae given for a rectangular triangle:
about aa axis
I=1/18md^2
about bb axis (through G)
I=1/18mh^2
because we want the inertia about xx axis I used =1/18md^2 where d=distance to xx axis=200mm
DevonZA said:
about aa axis
I=1/18md^2
I don't know what you mean by aa axis here, but that expression is for the moment of inertia about an axis through the centroid and parallel to one side. d is the width orthogonal to the axis. So here, d=0.6 for an axis through the centroid and parallel to the x axis.
To get from that axis to the xx axis itself you need to use the parallel axis theorem.
  • · Replies 28 ·
