Centripetal Acceleration of Satellite
The discussion revolves around a problem involving the calculation of centripetal acceleration for a satellite in orbit around the Earth. The original poster presents their attempt to derive the centripetal acceleration using gravitational principles.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to calculate centripetal acceleration using the formula involving gravitational force and tangential velocity. Participants question whether the original poster has confused centripetal velocity with centripetal acceleration and discuss the implications of this misunderstanding.
Participants are engaged in clarifying the distinction between centripetal acceleration and tangential velocity. Some guidance has been offered regarding the correct interpretation of the quantities involved, but there is no explicit consensus on the resolution of the original poster's confusion.
There is an indication that the original poster may have misinterpreted the problem's requirements, leading to a calculation that does not align with the expected outcome. The discussion highlights the importance of understanding the definitions and relationships between the different types of velocities and accelerations in orbital mechanics.
Physics53
Hi, I am stuck on this question:
A satellite of mass 1200 kg is in orbit around the Earth at a distance of 22000 km from the centre of the Earth.
Calculate the magnitude of the centripetal acceleration of the satellite at this distance.
I did:
mv^2/r= GMm/r^2
so v= square root of GM/r
v= square root of 6.67 x10^-11 x 6.0 x 10^24/ 22000 x 10^3
this gave me=
4.266x 10^-3 m/s but the answer at the back is 0.83 m/s^2, can someone please explain to where i went wrong.
Thanks[/B]
Carefully reread the question and make sure you're answering it.
Hi, I've reread it many time, but i still feel confused
What's it asking you to find? What did you actually calculate?
Oh I see what you mean, are you implying that I solved centripetal velocity instead of centripetal acceleration?
Essentially. You solved for what's sometimes called the tangential velocity, not centripetal velocity.
So does this mean I consider gravity of Earth as my centripetal velocity and therefore:
g= GM/r^2, but i still have a query, if you could kindly clear this up for me, why can't we use the centripetal formula in this question.
The work you did was correct, but you didn't actually solve for the quantity you were asked for. (The fact that the units were different is a big clue.)
I was just pointing out the phrase "centripetal velocity" doesn't really make sense. The velocity you found is tangent to the satellite's path; it doesn't point inward. The acceleration, however, does, so that's why it's referred to as centripetal acceleration.
  • · Replies 23 ·
