Understanding Centripetal and Centrifugal Force on a Rotating Platform
  • Thread starter Thread starter Dianne Werner
    Force
The discussion centers on the mechanics of centripetal and centrifugal forces experienced on a rotating platform while holding a spinning wheel. Participants clarify that the Earth's rotation has a negligible effect on the observed spinning behavior. The primary reason for spinning faster in a clockwise direction when tilting the axis is attributed to the inertia and centrifugal force acting in opposition to the direction of the wheel's spin. The conversation emphasizes that measurement uncertainties may account for any perceived discrepancies in rotational speed.
  • Understanding of centripetal and centrifugal forces
  • Basic principles of rotational dynamics
  • Familiarity with torque and its effects
  • Knowledge of inertia and angular momentum
  • Study the principles of angular momentum conservation
  • Explore the effects of torque on rotating systems
  • Investigate the role of measurement uncertainties in experimental physics
  • Learn about the dynamics of spinning objects and their interaction with forces
Physics students, educators, and anyone interested in understanding the dynamics of rotating systems and the effects of forces in motion.
Dianne Werner
If you are in the Northern Hemisphere and you stand on a rotating platform holding a spinning wheel and you tilt the axis so that your left hand is up and the right hand is down, why do you spin clockwise faster than the opposite way?(Right hand up?) It seems like since in the Northern Hemisphere the Earth spins counter clockwise, that the opposite would be true? Which way would the Torque push hardest? My experiment shows clockwise and I need to know why?
Do you think that you would spin faster clockwise because when the axis is tilted so that the left hand is up, the wheel would be spinning in the same direction as the Earth's rotation and the inertia or centrifugal force would push in the opposite direction?
Welcome to the PF. :smile:
What reading have you been doing trying to answer this question?
The hemisphere you are on doesn't matter for reasonable parameters of the setup. Any differences you see should come from measurement uncertainties or other issues.
Are you saying that the force should be just as strong clockwise as counter clockwise?
It doesn't have anything to do with the rotation of the Earth?
The rotation of Earth is completely negligible and its effect might be exactly zero in the setup you consider.
On a horizontal axis? Is the top of the wheel spinning towards you or away from you? Which way are you facing?
And what has this to do with centrifugal/centripetal?
But as mfb says, unless the wheel is huge, or spinning very fast, you will find it hard to detect an effect stronger than noise.
Consider the size of that effect.
It takes Earth 24 hours to turn 360 degrees.
How many minutes does it take to turn just a single degree?
Was the platform actually a chair? Is it the sort that you rotate to adjust the height?
  • · Replies 25 ·
