Centripetal force + uncertainty
The discussion centers on calculating centripetal force using the formula F = (mv²) / r, with specific values for mass, velocity, and radius. The mass is 2.8 ± 0.1 kg, velocity is 14 ± 2 m/s, and radius is 8.0 ± 0.2 m. The correct calculation for force yields F = 69 ± 14 N after considering the uncertainties in each variable, particularly noting that the uncertainty in velocity must be doubled due to squaring. The final consensus emphasizes the importance of calculating percentage uncertainties for accurate results.
  • Understanding of centripetal force and its formula F = (mv²) / r
  • Basic knowledge of uncertainty propagation in measurements
  • Ability to calculate percentage uncertainties for variables
  • Familiarity with significant figures in scientific calculations
  • Learn about uncertainty propagation techniques in physics
  • Study the concept of percentage uncertainty and its application
  • Explore advanced topics in dynamics, including centripetal acceleration
  • Review examples of force calculations with varying degrees of uncertainty
Students in physics, particularly those tackling problems involving centripetal force and uncertainty, as well as educators looking for examples of uncertainty propagation in calculations.
Wa1337
The centripetal force is given by F= (mv2) / r. If the mass is measured to be 2.8 +/- 0.1 kg, the velocity is 14 +/- 2 ms^-1, and the radius 8.0 +/- 0.2 m, find the force on the mass, including the uncertainty.
F= (mv2) / r
0.1/2.8 = .04
2/14 = .14
.2/8.0 = .025
add all up and i got .205
I did the equation and got 69 (2 sig figs) and finally got F = 69 +/- .21
Is that the proper uncertainty answer? If not please help.
edit: nvm
final answer then: F = 270 +/- .21 ? (2 sig figs both)
Wa1337 said:
edit: nvm
I did not say the force was wrong but you changed it; moreover, you still don't have the uncertainty right as I understand it.
I guess I'm not helping.
I'm sorry I kind of don't get it cause I'm really new to this stuff but my final answer without changing the force is:
F = 69 +/- 14
is that better? thanks
F = 69 +/- 14
You were closer in your original post.
Wa1337 said:
0.1/2.8 = .04
2/14 = .14
.2/8.0 = .025
Why is no one helping with this? I'm about to give him the answer as I think it is--it's really not something I do day-to-day but IAW to site I posted previously.
We are surpassing Winston Chruchill adage here "The Americans and the British are a single people divided only by a common language."
Well he has to get the percentage uncertainties for each of the values.
So for example, for velocity it would 2/14*100 = 14.28% (quite a large uncertainty there)
Since it's squared, the uncertainty would be double: 28.57%
Do this for each of the variables, and add up the percentages. Then your final percentage of the calculated value for force should be your uncertainty in Newtons.
  • · Replies 17 ·
