Centripetal vs Radial acceleration
Centripetal acceleration (a_c) is defined as the acceleration directed towards the center of a circular path, calculated using the formula a_c = v^2/r. Radial acceleration (a_r), on the other hand, can be negative, represented as a_r = -a_c, indicating its direction is opposite to the radial unit vector pointing away from the origin. This negative sign reflects the convention that centripetal acceleration is always directed inward, while radial acceleration can vary in direction based on the context of the motion. Understanding these distinctions is crucial for interpreting motion in circular paths and spherical coordinates.
  • Understanding of basic physics concepts, particularly circular motion
  • Familiarity with acceleration types: centripetal and radial
  • Knowledge of mathematical formulas related to motion, specifically a_c = v^2/r
  • Basic comprehension of spherical coordinates and vector projections
  • Study the implications of sign conventions in physics, particularly in circular motion
  • Explore the concept of spherical coordinates and their applications in physics
  • Learn about vector projections and their significance in acceleration analysis
  • Investigate examples of centripetal acceleration in real-world scenarios, such as planetary motion
Students of physics, educators explaining circular motion, and anyone interested in the mathematical foundations of acceleration in various coordinate systems.
Amio
I am reading introductory physics from Serway. Where they say if a_r is radial acceleration and a_c is centripetal acceleration then a_c = v^2/r and a_r = -a_c = - v^2/r
But aren't the radial and centripetal acceleration same (correct me if I am wrong)? Why is there a minus sign?
The book explains by saying that the negative sign indicates that the direction of centripetal acceleration is towards the center of the circle representing the radius of curvature..
I don't understand this explanation because as the direction of the radial acceleration is also towards the center, shouldn't it be a_{radial} = a_{centripetal} ? Why the minus sign?
Would someone please clarify?
Do you know what spherical coordinates are? The radial component of a vector is the projection of that vector onto the radial unit vector. That vector points away from the origin. Thus the radial component of acceleration is positive if the acceleration vector is pointing away from the origin.
Centripetal acceleration is acceleration toward the center.
It's just a sign convention, nothing else.
Thank you.
The term centripetal acceleration applies only when an object is following a curved path, and by definition the centripetal acceleration is always positive. On the other hand acceleration can have a positive or negative radial component. Consider two electrons moving toward another, for example, with the origin at the center of mass. The radial component of acceleration will be positive because like charges repel.
  • · Replies 21 ·
9K
  • · Replies 16 ·
  • · Replies 37 ·
  • · Replies 24 ·
