Challenging Math Problems for the Curious Mind
  • Thread starter Thread starter benorin
19 replies · 4K views · last reply
Insights Author
Would someone please post a good problem (or at least an interesting one) for me to work on, say calculus, real/complex analysis, or some generating function stuff, or some problem anybody can understand but will scratch their head at? I really bored. Thanks for cherring me up,
-Ben
OK-
If P is a polygon, prove that it cannot be the union of disjoint convex quadrilaterals, each of which has exactly one face that is also a face of P.
A particle is moving on the line y=x^3 in the first quadrant starting from Origin at a speed dy/dx=1 unit per...time unit. ignore units. :p
Question is...find a formula for the angle formed by the x-axis and a line created by the Origin and the particle's position.
In all honesty I saw it before but I never took the time to solve it. I doubt i can however ... :(
Find the sum:
[tex] \sum_{i = 0}^{+\infty}<br /> \tan^{-1} \frac{1}{1 + x + x^2}[/tex]
(I think I have that right)
Hurkyl said:
Find the sum:
Quite easy: it is a diverging series ...
:rolleyes:
Hurkyl,
[tex]\sum_{x = 0}^{+\infty}\tan^{-1} \frac{1}{1 + x + x^2} = \sum_{x = 0}^{+\infty}\tan^{-1} \frac{(x+1)-x}{1 + (x+1)x} = \sum_{x = 0}^{+\infty}\left( \tan^{-1}(x+1)-\tan^{-1}x\right) = \lim_{M\rightarrow\infty} \tan^{-1}(M+1)-\tan^{-1}(0)= \frac{\pi}{2}[/tex]
Thanks,
-Ben
Try with this.
Find the product
[tex]\prod_{k=1}^{\infty} \left( 1 + \frac{2}{k^2 + 7} \right)[/tex].
Well, I have a problem which currently bugs me (although I think I already solved it). Find the solution to the differential equation:
dv/dt = a*v+b*v^2.
It represents the movement of a particle with a velocity dependent friction force (which is proportional to v for small v and proportional to v^2 for large v). So the solution must be equal to the stokes case for small values of v and equal to the Newton case for large values of v, that´s how you can check if your answer is correct.
I made the problem up myself, so it might not be physically correct. But at least it´s a solvable DE which you can make into a linear first order ODE by substitution. Sorry for my english.
WigneRacah said:
Try with this.
Find the product
Since [tex]\frac{\sin \pi x}{\pi x}=\prod_{k=1}^{\infty} \left( 1-\frac{x^2}{k^2}\right) = \prod_{k=1}^{\infty} \frac{k^2-x^2}{k^2}[/tex] it follows that
[tex]\frac{y}{x}\frac{\sin \pi x}{\sin \pi y}= \prod_{k=1}^{\infty} \frac{k^2-x^2}{k^2-y^2}[/tex]
[tex]\prod_{k=1}^{\infty} \left( 1 + \frac{2}{k^2 + 7} \right) = \prod_{k=1}^{\infty} \frac{k^2+9}{k^2 + 7} = \frac{\sqrt{7}}{3}\frac{\sin 3\pi i}{\sin \sqrt{7}\pi i}[/tex]​
recall that [tex]\sin iz = i\mbox{sinh}z[/tex] to get the final value, namely
[tex]\boxed{\prod_{k=1}^{\infty} \left( 1 + \frac{2}{k^2 + 7} \right) = \frac{\sqrt{7}}{3}\frac{\mbox{sinh} 3\pi}{\mbox{sinh} \sqrt{7}\pi } = \frac{\sqrt{7}}{3}\frac{e^{3\pi}-e^{-3\pi} }{e^{\sqrt{7}\pi}-e^{-\sqrt{7}\pi} }}[/tex]​
1. Prove from first principles that exp(x) is indeed (1+x/s)^s as s tends to infinity.
2. If M is a matrix over the complex numbers and Tr(M^r)=0 for all r show that all eigenvalues of M are zero.
3. If f is a function from C to C and the integral of f round any triangle is zero show that f is analytic/holomorphic.
4. What is the genus of the Riemann surface corresponding to w=sqrt((z-1)(z-2)(z-3)..(z-n))
5. Prove, using homology groups, the fundamental theorem of algebra. Hint, this is actually a fixed point theorem.
(Note: one of these is tricky, one of these probably requires more material than you've yet learnt.)
I'll do the easy one (it was homework in grad real analysis with Papa Rudin).
I assume that we have the definition [tex]e^x=\sum_{k=0}^{\infty}\frac{x^k}{k!}[/tex].
Let [tex]f_{s}(x)=\left(1+\frac{x}{s}\right) ^s[/tex]. Define [tex](a)_{k}:=a(a-1)\cdots (a-k+1)[/tex] and [tex](a)_{0}=1[/tex] (that is put [tex](a)_{k}= \frac{\Gamma (a+1)}{\Gamma (a-k+1)}[/tex] for [tex]k\in\mathbb{N}[/tex]. Now notice that
[tex]f_{s}^{(k)}(x)=\frac{(s)_{k}}{s^k}\left(1+\frac{x}{s}\right) ^{s-k},[/tex] for [tex]k\in\mathbb{N}[/tex]​
hence
[tex]f_{s}^{(k)}(0)=\frac{(s)_{k}}{s^k}[/tex] for [tex]k\in\mathbb{N}[/tex]​
so that we have the MacClaurin Series for [tex]f_s(x)[/tex] as being
[tex]f_{s}(x)=\sum_{k=0}^{\infty}\frac{(s)_{k}}{k!}\left( \frac{x}{s}\right) ^{k}[/tex]​
Consider the quantity
[tex]\left|f_{s}(x)-e^x\right| = \left|\sum_{k=0}^{\infty}\frac{(s)_{k}}{k!}\left( \frac{x}{s}\right) ^{k}-\sum_{k=0}^{\infty}\frac{x^k}{k!} \right|= \left|\sum_{k=0}^{\infty} \frac{x^k}{k!}\left(\frac{(s)_{k}}{s^k}-1\right)\right|[/tex]
[tex]\leq \sum_{k=0}^{\infty} \frac{|x| ^k}{k!}\left|\frac{(s)_{k}}{s^k}-1\right|[/tex]​
and note that [tex](s)_{k}=s(s-1)\cdots (s-k+1) \sim s^k\mbox{ as }s\rightarrow\infty[/tex] so that we have [tex]\left|f_{s}(x)-e^x\right|\rightarrow 0, \mbox{ as }s\rightarrow\infty[/tex].
BTW, Hurkyl, this problem was PUTNAM 1986/A-3.
benorin said:
Hurkyl,
Thanks,
-Ben
How much wood could a woodchuck chuck if a woodchuck could chuck wood?
Answer in terms of the variables x, y, and photons.
Then the cubed root of it.
This one's been bothering me personally.
Thanks.
Ah, double posted my question.
-Ben
How about this one:
https://www.physicsforums.com/showthread.php?t=150136
:smile:
