Charge on a capacitor in a series
1 reply · 3K views · last reply
acdurbin953
Circuit diagram with a battery V on the left, capacitors C1 on the top wire and C5 on the bottom wire, and C2 and C3 in series with C4 in parallel between nodes b and a; nodes c, b and a are labeled.
[/B]
A circuit is constructed with five capacitors and a battery as shown. The values for the capacitors are: C1 = C5 = 3.9 μF, C2 = 3.9 μF, C3 = 5.7 μF, and C4 = 4.2 μF. The battery voltage is V = 12 V.
What is Q5, the charge on capacitor C5?
C=Q/V
Okay, I thought that voltage across series capacitors was all the same across each one. Treating the parallel system as one capacitor of equivalent capacitance, I thought you could just divide the voltage by 3, and then multiply by C5 to get the charge on C5. I tried this and the answer is wrong. I'm really confused.
acdurbin953 said:
Circuit schematic with a voltage source V on the left and five capacitors labeled C1 through C5, with nodes labeled a, b and c. C1 is in the top wire, C2 and C3 are in series in a vertical branch between nodes b and a, C4 is in a parallel branch on the right, and C5 is in the bottom wire.
[/B]
C=Q/V
The voltage across capacitors in series is not the same, unless the capacitances are equal. What is the resultant of C2, C3 and C4? Is it equal to 3.9 μF?
I think you mix charge with voltage. The charge is same on series capacitors .
