Chebyshev's theorem: finding k for upper tail probability
  • Context: Undergrad
  • Thread starter Thread starter idioteque
    Theorem
6 replies · 6K views
idioteque
the test scores for a large statistics class have an unknown distribution with a mean of 70 and a standard deviation of 10
find k so that at most 10% of the scores are more than k standard deviations above the mean.
I'm a bit confused by the question it self.
does the question means :
1-1/k^2 = 0.1
k = 1.05
or
1-1/k^2 = 0.2
k = 1.12
or
1-1/k^2 = 0.8
k = square root 5 = 2.23
pls help, thanks in advance.
to avoid being flamed for homework type of question, I added my own opinion towards this question. your help is very much appreciated.
I misread your question. The minimal value for k given "at most" 10% k SDs above the mean would be [tex]1-1/k^2=0.8[/tex] so [tex]k=2.236[/tex]. This assumes your distribution is perfectly symmetrical.
'at most' 10%.
why take the other remaining 80%?
it asked for 'at most' 10%.
doesn't this mean anything not greater than 10%?
if it asked 'at least' 10% then anything greater than 10%
idioteque said:
'at most' 10%.
why take the other remaining 80%?m
80% of the test scores are within 2.236 SD of the mean. 10% are at least 2.236 SD above the mean, 10% at least 2.236 SD below the mean. This is the minimal value of k. If you want to be sure that at most 10% are more than k SD above the mean, take any arbitrary value of k greater than 2.236. That's the way I read it anyway.
ok thank you. I got it.
the keyword is above the mean.
the value of k before the last 10% of each side(20%). so 80% is in between the 20%
is how I interpreted it as it is.
correct?
correct?
Correct.
