Checking limit problems homework
4 replies · 2K views · last reply
styxrihocc
Hey I just need someone to check my work to make sure I did it right, thanks.
Limit expression: lim as x approaches infinity of ln((x - 3)/x) raised to the power 2x + 10.
Equation: lim as x approaches infinity of ln((x - 3)/x)^(2x+10) = ln lim as x approaches infinity of (1 - 3/x)^(2x+10).
Typeset equation: ln lim as x approaches infinity of (1 - 3/x)^(2x+10) = e^(ln lim as x approaches infinity of (-3/x)(2x+10)).
Expression e raised to the power ln of the limit as x approaches infinity of (-6x - 30)/x.
Typeset equation e^(ln -6) = -6
Handwritten-style limit expression: lim as x approaches infinity of ln((x - 3)/x) raised to the power 2x + 10.
Math equation: ln lim as x→∞ of (1 − 3/x)^(2x+10) = e^(ln lim as x→∞ of (−3/x · 2x + 10))
The step above has an error. ln <whatever> ≠ eln<whatever>.
Also, how did you go from (1 - 3/x)2x + 10 to (-3/x *2x + 10)?
Finally, eln(-6) ≠ -6, because ln(-6) is undefined.
styxrihocc said:
Expression e raised to the power of ln of the limit as x approaches infinity of (-6x - 30)/x, written in LaTeX-style typesetting.
Handwritten equation e^(ln -6) = -6
I should mention that posting a bunch of images of the work you've done makes it much more difficult to point out where errors happen to be. Using LaTeX you can format your work exactly as you have it in the images you uploaded.
Sorry but typing in latex takes too long so i just cropped the pics straight from my doc file
from this formula in my textbook:
Equation: lim as x approaches c of [1 + f(x)] raised to g(x), equals e raised to the power of (lim as x approaches c of f(x)) times (lim as x approaches c of g(x)).
Anyway seeing as my answer is wrong how should i go about this problem?
What turns out to be a convenience for you is inconvenient for me, and possibly others at this site whose help you are seeking.
Limit identity: lim as x approaches c of [1 + f(x)] raised to g(x) equals e raised to the power of (lim f(x) times lim g(x)), both limits as x approaches c.
Are you sure you typed the formula correctly? I've never seen the formula that you wrote, and I'm pretty sure it is incorrect.
Your answer is correct, but you work along the way is not for the reasons I already gave.
The easiest thing to do is to rewrite ln(1 - 3/x)2x + 10 as (2x + 10)*ln(1 - 3/x), and then rearrange so that you can use L'Hopital's Rule.
