Finding Your Mistake: Solving a Limit Problem
  • Thread starter Thread starter Aliax3012
    Limit Mistake
The discussion centers on solving a limit problem involving the function ##f(x)=x^4## and determining the appropriate ##\delta## such that ##|f(x)-L|<\epsilon## for all ##x## satisfying ##0<|x-a|<\delta##. The initial approach involved factoring ##x^4 - a^4## incorrectly, leading to confusion about the correct choice of ##\delta##. After receiving guidance, the user successfully reformulated the problem and derived a correct expression for ##\delta##, which included terms like ##2(|a|+1)## and ##2(|a^2|+1)##, clarifying the discrepancy in their initial calculations.
  • Understanding of limit definitions in calculus
  • Familiarity with polynomial functions and their properties
  • Knowledge of the triangle inequality in mathematical analysis
  • Ability to manipulate inequalities and factor polynomials
  • Study the definition of limits in calculus, focusing on epsilon-delta proofs
  • Learn about polynomial factorization techniques, specifically for higher-degree polynomials
  • Explore the triangle inequality and its applications in limit proofs
  • Review common mistakes in limit problems and how to avoid them
Students studying calculus, particularly those focusing on limits and continuity, as well as educators looking for examples of common pitfalls in limit proofs.
Aliax3012
I've pondered at this problem for a long time, and I don't know where I make a mistake, can anyone give me a hint?
1. Homework Statement
find a ##\delta## such that ##|f(x)-L|<\epsilon## for all x satisfying ##0<|x-a|<\delta##
[/B]
##f(x)=x^4##; ##l=a^4##
[/B]
writing as the definition of limits
if ##|x-a|<\delta ##, then ##|x^4-a^4|<\epsilon##
factor the right side of equation I got
##|(x^2-a^2)(x^2+a^2)|<\epsilon##, then I can have ##|x^2-a^2|<\delta_1##
chose ##\delta_1=min(1)##, and I got ##|x^2|-|a^2|\le|x^2-a^2|<1##, adding |a^2| to both side of the inequality I got ##|x^2|<1+|a^2|##, therefore ##|x^2|+|a^2|<1+2|a^2|## , and ##|x^2+a^2|\le|x^2|+|a^2|<2|a^2|+1##
So I choose ##\delta_1=min (1, \frac{\epsilon}{2|a^2|+1})##
Therefore I have, if ##|x-a|<\delta## , then ##|x^2-a^2|<min (1, \frac{\epsilon}{2|a^2|+1})##
from my previous experience with ##\lim_{x \to a} x^2## , I know that I can pick ##\delta=min(1, \frac{\epsilon}{2|a|+1})##, under these conditions
if ##|x^2-a^2|<\epsilon##, then ##|x-a|<\delta##
so if I let ##min(1, \frac{\epsilon}{2|a^2|+1})## play the role of ##\epsilon##,
and I got ##\delta=min(1, \frac{min(1,\frac{\epsilon}{2|a^2|+1})}{2|a|+1})##
when I check the solution, it seems like I got the right idea but the solution assume ##\delta=min(1, \frac{min(1, \frac{\epsilon}{2(|a^2|+1)})}{2(|a|+1)})##
for some reason, I suppose I miss out a factor of two somewhere, but I check it again and again and could not find where I make a mistake, can somebody give me a clue?
[/B]
[/B]
Instead of factoring ##x^4 - a^4 = (x^2 - a^2)(x^2 + a^4)##, look at the right side of this equation as ##(x - a)(x + a)(x^2 + a^2) = (x - a)(x^3 + ax^2 + a^2x + a^3)##
Thank you for your reply Mark
Following your advice I got this,
Second Attempt at the Solution,
writing givens as the definition of limits
if ##|x-a|<\delta## then ##|x^4-a^4|<\epsilon##
factoring out the right side of the condition
##|(x-1)(x^3+a^2x+ax^2+a^3)|<\epsilon##
choose ##\delta=min(1)## then I got, ##|x-a|<1##, using triangle inequality I got ##|x|-|a|\le|x-a|<1##, set ##|x|-|a|<1##, and I got ##|x|<1+|a|##
rewrite the expression ##|(x^3+a^2x+ax^2+a^3)|\le|x^3|+|a^2|\times|x|+|a|\times|x^2|+|a^3|##
Now, I sub ##|x|## in, and the final result is ##|(1+|a|)|^3+|a^2|\times|(1+|a|)|+|a|\times|(1+|a|)|^2+|a^3||##
now, I just choose that ##\delta=min(1, \frac{\epsilon}{|(1+|a|)|^3+|a^2|\times|(1+|a|)|+|a|\times|(1+|a|)|^2+|a^3|})##
When I check the result, it matched up with the solution the book has given out in this second method, I'm just curious on why I got a different answer in first method that I choose to find ##\delta##, it seems that I got the right methodology in the first one but just different answer and I don't know where I make my mistake, I don't know where the book got ##2(|a|+1)## and ##2(|a^2|+1)## instead of ##2|a|+1## and ##2|a^2|+1##, I check again and again to see where I miss the 1 but I just can't find it, Thank you for your time Mark
  • · Replies 31 ·
