Checking understanding on factors affecting thermal equilibrium
This discussion focuses on the factors affecting the thermal equilibrium of an object, particularly when heated. Key factors identified include Specific Heat Capacity, Mass, Rate of Heat Supplied, Surrounding Temperature, Color, Material, Wind Velocity, and Exposed Surface Area. Each factor influences the equilibrium temperature, with higher specific heat capacity and mass leading to a slower temperature change, while increased heat supply and surrounding temperature elevate the equilibrium temperature. Additionally, darker colors and larger surface areas contribute to heat loss, lowering the equilibrium temperature.
  • Understanding of Specific Heat Capacity
  • Knowledge of thermal conductivity
  • Familiarity with heat transfer principles
  • Basic concepts of thermal equilibrium
  • Research the concept of Specific Heat Capacity in detail
  • Explore the principles of heat transfer, including conduction, convection, and radiation
  • Study the effects of surface area on heat exchange
  • Learn about the impact of color and material properties on thermal behavior
Students in physics or thermodynamics, educators teaching heat transfer concepts, and anyone interested in understanding thermal equilibrium in practical applications.
qazxsw11111
Ok, so I got this question that is about factors affecting the thermal equilibrium of an object when heated when factors are altered.
Basically, the setup is that the object is heated (Maybe a glass of water heated) and we are supposed to find out what factors affect the eqm temp of the object.
So I got a list of factors (But not sure of explaining them!):
1)Specific Heat Capacity of Object
2)Mass of object
3)Rate of heat supplied
4)Surrounding temperature
5)Color of object
6)Material of object
7)Wind velocity of surroundings
8)Larger exposed surface area
I listed them down but I am not sure on how to explain their effect on thermal equilibrium of an object which is being heated. Ok, so for
1)The higher the shc of object, the... (not sure how to explain)
2)Same as above
3)Higher the rate of heat supplied, the higher the eqm temp as a higher temperature needs to be reached to increase the temperature difference btw surrounding and object, so that heat loss=heat gain. (Is this correct, or confusing)
4)Larger diff, the ... (how to explain)
5)Darker Color-->More heat radiated-->Lower eqm temp?
6)Material with higher thermal conductivity-->Lose heat more easily-->Lower eqm temp?
7)Increase in wind velocity-->increase temp diff grad-->Lower eqm temp?
8)Larger exposed S.A. -->More heat loss-->Lower eqm temp?
Im not really good at explaining. Please help me with my queries.
Thank you all so much for your time.
Science news on Phys.org
Please help explain and elaborate on the points. I am not very good conceptually and need help. Thanks a lot.
Help anyone? Need it for a class later.
  • · Replies 23 ·
  • · Replies 135 ·
  • · Replies 16 ·
14K
  • · Replies 19 ·
