Chirality of Naproxen: Explaining With CIP Rules
  • Thread starter Thread starter miniradman
    Chirality
The discussion focuses on determining the chirality of Naproxen using the Cahn–Ingold–Prelog (CIP) rules. The stereocenter is identified at the carbon where the carboxyl group meets the two benzene rings. Participants clarify that the priorities of the substituents are based on atomic numbers, with the carboxyl group having higher priority due to the presence of oxygen. The ambiguity arises when deciding the path to take when multiple branches are present, particularly with aromatic rings.
  • Understanding of chirality and stereocenters in organic chemistry
  • Familiarity with Cahn–Ingold–Prelog (CIP) rules for assigning priorities
  • Knowledge of functional groups, specifically carboxylic acids and aromatic compounds
  • Basic understanding of molecular geometry and bond rotation
  • Study advanced applications of Cahn–Ingold–Prelog rules in complex molecules
  • Learn about stereoisomerism and its implications in pharmaceuticals
  • Explore the concept of multiple bonds and their impact on chirality
  • Investigate the role of chirality in drug design and efficacy
Chemistry students, organic chemists, and pharmaceutical researchers interested in stereochemistry and its applications in drug development.
miniradman
determine and explain its chirality using the CIP rule
*see attached image*
CIP rules
Hello
I've determined that the stereocenter of this molecule is at the carbon where the carboxyl group meets the two benzene rings.
I've done step one and rotated the stereocenter such that the hydrogen is facing back. However when deciding the priorities of the three constituents on the stereocenter I get a little confused.
When going down the chain, towards the aromatic rings that I'll encounter a double bond. I tried reading how these fit in with the CIP rules but I find them to be quite ambiguous.
And with the carboxyl group, when going down the chain, which direction do I have to go? Down the hydroxyl group on the double bonded oxygen? I
Thanks
- miniradman
You have identified the correct chiral center. These are the three groups I see.
Methyl
Ring
Carboxylic acid
I do not know what CIP rules are.
Cahn–Ingold–Prelog
Your chiral carbon is attached to:
1) A hydrogen.
2) A carbon which is attached to 3 or so oxygen atoms (because m.ultiple bonds are counted as equivalent number of single bonds, from memory)
3) a carbon which is attached to 3 carbon atoms (same as above).
Can you do it now?
1) A hydrogen.
Can you do it now?
Well since oxygen has a higher atomic number than carbon, I assume the carboxyl group has more priority.
However, intuitively, if I were to have another single aromatic ring in place of the carboxyl group, how would I go about going down the branches? Which would then be of highest priority? I get confused on where to go once you start having to decide which branch to take.
