Circular Motion and carnival ride
The discussion focuses on calculating the maximum rotation period (T) of a vertical cylinder amusement park ride that prevents a 47 kg person from falling due to gravity (9.8 m/s²) and static friction (coefficient of 0.337). The radius of the cylinder is 5.8 m. The initial calculations led to an incorrect value of T = 8.326 seconds. The correct approach involves equating the frictional force (Ff) to the gravitational force acting on the person, ensuring that Ff equals the weight of the person (m*g). The correct normal force must be determined to find the accurate rotation period.
  • Understanding of circular motion principles
  • Knowledge of static friction and its coefficient
  • Familiarity with Newton's second law of motion
  • Ability to manipulate equations involving velocity and acceleration
  • Review the derivation of centripetal acceleration in circular motion
  • Study the relationship between normal force and frictional force
  • Learn about the implications of static friction in real-world applications
  • Explore the effects of varying mass and radius on rotation period in similar scenarios
Physics students, engineering students, and anyone interested in the mechanics of amusement park rides and circular motion dynamics.
all_relative
An amusement park ride consists of a large vertical cylinder that spins about its axis fast enough that a person inside is stuck to the wall and does not slide down when the floor drops away. The acceleration of gravity is 9.8m/s^2.
Given g=9.8 m/s^2, the coefficient of static friction between the person and the wall = 0.337. The radius of the cylinder, R=5.8m. For simplicity, neglect the person's depth and assume he or she is just a physical point on the wall. The person's speed is v= (2{pi}R)/T where T is the rotation period of the cylinder (the time to complete a full circle).
Find the maximum rotation period T of the cylinder which would prevent a 47kg person from falling down. Answer in units of seconds.
*For clarity this ride is one that spins and the person is pressed against the wall*
-attached is an image of the ride-
v= (2{pi}R)/T
Ff=(coefficient of friction)(Fn)
Ff=m*((v^2)/R)
M=coefficient of Friction
m=mass
Ff=M(Fn)
Ff=(0.337)(460.6)
Ff=155.22
Ff=m*((v^2)/R)
155.22=47*v^2/5.8
v=4.3766m/s^2
v= (2{pi}R)/T
4.3766=2{pi}(5.8)/T
T=8.326 seconds
-this answer is wrong-
Almost - you are trying to find what normal force is needed so that the frictional force is equal to their weight.
Thanks for the reply.
However, I am still confused as to what I need to do.
Does Ff=47?
