Circular Motion of a ball Problem
6 replies · 17K views
cse63146
A 60 g ball is tied to the end of a 50-cm-long string and swung in a vertical circle. The center of the circle, as shown in Figure, is 150 cm above the floor. The ball is swung at the minimum speed necessary to make it over the top without the string going slack.
If the string is released at the instant the ball is at the top of the loop, where does the ball hit the ground?
http://session.masteringphysics.com/problemAsset/1000600/5/knight_Figure_07_62.jpg
Critical velocity = [tex]V{c}[/tex] = [tex]\sqrt{r*g}[/tex]
[tex]\Delta[/tex]d=V{i}*t + (1/2)(a)(t^2)
I attempted this problem as a projectile motion problem, and divided the calculations into two parts: Horizontal and vertical
vertical Part
So I used this equation: [tex]\Delta[/tex]d=V{i}*t + (1/2)(a)(t^2) and I know the vertical initial is 0 so I can eliminate V{i}*t of the equation and get: [tex]\Delta[/tex]d=(1/2)(a)(t^2)
2 = (1/2)*(9.8)*(t^2)
2 = 4.9*(t^2)
t^2 = 2 / 49
t = 0.64 seconds
Horizontal Part
The horizontal parts only has 3 variables: V, d, and t (which I know from the vertical part). and V = V{c} = [tex]\sqrt{r*g}[/tex] = 0.59 m/s.
and d = v*t = 0.59*0.64 = 0.3776 m
This doesn't look right. I was wondering if someone can point me in the right direction. Any help is greatly appreciated. Thanks.
yea I see what you mean. I accidently used the mass instead of the radius.
so it would be v_{c}=[tex]\sqrt{r*g}[/tex] = [tex]\sqrt{0.5*9.8}[/tex] = 6.9
therefore:
d = v*t = (6.9) * (0.64) = 4.4 m/s?
Does this seem right?
Edit: Still not the right answer. Help?
What are you asked to find? (I don't see a question in the problem statement.)
oops.Sorry about that.
therefore:
you've made anoteher math error,
[tex]\sqrt{r*g}[/tex] = [tex]\sqrt{0.5*9.8}= \sqrt4.9 = 2.2m/s[/tex] And then calculate the distance d which wil be in meters.
yep
d = v*t = 2.2*0.64 = 1.4 m
Thanks a lot!
still can't figure out why I put down 6.9 instead of 4.9...
