Circular Motion - Satellites Problem
The problem involves two satellites, S1 and S2, orbiting Earth at different distances and speeds. S1 orbits at a distance r with speed v, while S2 orbits at a distance 2r with speed (v/sqrt(2)). The centripetal forces for both satellites are calculated using the formula F = mv²/r. After correcting an algebra error, the ratio of the centripetal force on S1 to that on S2 is determined to be 4, confirming option C as the correct answer.
  • Understanding of centripetal force and its formula F = mv²/r
  • Knowledge of orbital mechanics and satellite motion
  • Basic algebra skills for manipulating equations
  • Familiarity with square roots and their application in physics
  • Study the derivation of centripetal force in circular motion
  • Learn about gravitational forces acting on satellites
  • Explore the concept of orbital velocity and its calculations
  • Investigate the effects of varying distances on satellite speed and force
Students studying physics, particularly those focusing on mechanics and orbital dynamics, as well as educators looking for examples of centripetal force applications in satellite motion.
Galileo_Galilei
Two satellites of equal mass, S1 and S2, orbit the earth. S1 is orbiting at a distance r from the Earth's center at speed v. S2 orbits at a distance 2r from the Earth's center at speed (v/squareroot2) . The ratio of the centripetal force on S1 to the centripetal force on S2 is,
A. 1/8
B. 1/4
C. 4
D. 8
F = mvsqrd/r
I just couldn't figure this one out at all... its frustrating, i tried playing around with the equation but i kept getting nonsense.
You have the correct equation. Show what you did to find F_1 and F_2 (the two centripetal forces).
Ok. So since the mass is equal its constant, so we just have
F = Vsquared/r
So then, S1 = Vsquared/r
S2 = (v/squareroot2)squared/2r
= (vsquared/2)/2r
= (2vsquared*r)/2
S1 = Vsquared/r
S2 = (2vsquared*r)/2
Hmm.. so now?
F = Vsquared/r
Ultimately, that's all you need, but it would be more correct to leave the mass in until the very end.
Right.
= (vsquared/2)/2r
= (2vsquared*r)/2
Correcct until F_{S2}=m\frac{\frac{v^2}{2}}{2r}
Then you have an algebra error.
Hmm.. so now?
The problem asks you to take calculate a ratio, ie, divide one of the forces by the other. (Incidentally, that's why you can leave the mass in until the very end: both forces have the term 'm' so the masses cancel).
Oh, yeah, algebra got me there.
So it'd have to then be:
S2 = {\frac{v^2}{4r}}
Ah, so now it gives me a much simpler division to do. When i divide those S1/S2 after multiplying and cancelling i get 4r/r.
Awesome, so the answer is 4. Thanks for pointing out the algebra mistake.
