Circular Movement Homework: Part A Done, Part B Troubles
13 replies · 3K views · last reply
asi123
Everything is in the pictures.
I did part A, I have a problem with part B.
10x in advance.
  • Diagram of a ball on a string of length l swinging in a vertical circle about a pivot, with the ball at the top moving left at speed V0 and angle θ measured from the vertical; a vertical dimension of 3l is marked from the ground line up to the level of the pivot.
  • Handwritten physics working in two parts: part A finds the minimum speed v0 for a ball to move in a circle at the top, giving v0 = sqrt(gR); part B works with tension and angle theta, with a free-body diagram showing T, mg and theta.
You need to find the tension as a function of angle. (Forget the tension at the top.)
You have the correct equation. Hint: Express v^2 as a function of angle.
I know this equation (in the pic) but I'm doubtful if this what you meant...
Should I use trigo? can I get another tip :smile:?
10x.
  • Equation written in blue monospaced text: m × w² × r = m × (θ/t)² × r, with θ over t grouped in parentheses and squared.
The equation I had in mind was: mv^2/r = T + mg cos(theta).
Another hint: What's conserved as the ball continues on its path?
Ok, I already wrote that equation at the beginning in the solution part I uploaded and got stuck there.
I got stuck because I don't know the velocity at this point, I mean, the velocity is not constant, right? there is a mgsin(theta) that keep changing it...I think.
The velocity at the top is not the velocity at the bottom, right?
10x.
The velocity is definitely not constant. Reread my hint in post #4. :wink:
Given the velocity at the top, you should be able to find the velocity at any point as a function of angle.
:confused: I'm totally stuck, should I use trigo, or there is some equation for the velocity that I don't know about...
Oh, maybe u mean to use energy calculation?
Getting warmer! :smile:
The potential energy turns into kinetic energy, no?
Ok, I haven't really learned Conservation of energy so I'm not really familiar with it...
I wrote this equation about the energy, is it correct?
And another thing, What about T? it's not a Conservative force, right? Do I just ignore it in the the energy equation?
10x.
  • Handwritten energy equation on grid paper: m V0^2 over 2 plus m g (4L) equals m v^2 over 2 plus m g (4L minus l cos theta).
Looks good to me.
Excellent question! Ask yourself: Does the tension force do any work on the ball?
Doc Al said:
Looks good to me.
Oh, right, it's vertical to his movement.
10x a lot.
The ball's movement is always perpendicular to the tension, thus the tension does no work on the ball.
