Circular Movement Homework: Part A Done, Part B Troubles
  • Thread starter Thread starter asi123
    Circular Movement
13 replies · 3K views
asi123
Everything is in the pictures.
I did part A, I have a problem with part B.
10x in advance.
You need to find the tension as a function of angle. (Forget the tension at the top.)
You have the correct equation. Hint: Express v^2 as a function of angle.
I know this equation (in the pic) but I'm doubtful if this what you meant...
Should I use trigo? can I get another tip :smile:?
10x.
The equation I had in mind was: mv^2/r = T + mg cos(theta).
Another hint: What's conserved as the ball continues on its path?
Ok, I already wrote that equation at the beginning in the solution part I uploaded and got stuck there.
I got stuck because I don't know the velocity at this point, I mean, the velocity is not constant, right? there is a mgsin(theta) that keep changing it...I think.
The velocity at the top is not the velocity at the bottom, right?
10x.
The velocity is definitely not constant. Reread my hint in post #4. :wink:
Given the velocity at the top, you should be able to find the velocity at any point as a function of angle.
:confused: I'm totally stuck, should I use trigo, or there is some equation for the velocity that I don't know about...
Oh, maybe u mean to use energy calculation?
Getting warmer! :smile:
The potential energy turns into kinetic energy, no?
Ok, I haven't really learned Conservation of energy so I'm not really familiar with it...
I wrote this equation about the energy, is it correct?
And another thing, What about T? it's not a Conservative force, right? Do I just ignore it in the the energy equation?
10x.
Looks good to me.
Excellent question! Ask yourself: Does the tension force do any work on the ball?
Doc Al said:
Looks good to me.
Oh, right, it's vertical to his movement.
10x a lot.
The ball's movement is always perpendicular to the tension, thus the tension does no work on the ball.
