Circumscribed Quadrilateral with Integer Sides and Radius
  • Level: Undergrad
  • Thread starter bob012345
16 replies · 1K views · last reply
bob012345
TL;DR
A 4 sided polygon is inscribed in a circle. The chord lengths are all distinct integers . Find the smallest possible integer radius of the circle and the length of the sides.
This is an offshoot of @Charles Link ’s problem; Consider again a 4 sided polygon inscribed in a circle. The chord lengths are all distinct integers ##a<b<c<d##. Find the smallest possible integer radius ##r## of the circle and the length of the sides.
anuttarasammyak said:
1,2,3,4 if 1,1,1,1 is excluded.
What is the radius?
Addendum
0,0,0,0 gives r=0. 0,0,2,2 gives r=1.
The side lengths must all be different as per the instructions in post #1.
Charles Link said:
One that I have is 2,7, 11, and 14 with r=7. Probably not the smallest.
I believe it is in fact the smallest integer radius with four different sides. If we take away that restriction the smallest is (1,1,1,2) with ##r=1##. The figure for that is half a hexagon within the circle. In your case, one of the sides was the diameter. If we ask now what is the smallest possible integer radius with four unique integer sides but not allowing one side to be a diameter, what do we get? I believe @anuttarasammyak is on the right track.
Addendum
Shown on the right is the quadrilateral (0,0,0,0) with ##R=0.##
  • Haha
Try 14,30,40, and 48 with r=25.
There are 431 cases for
$$d<a+b+c$$  $$1 \leq a < b< c< d \leq 12$$
Spreadsheet table with columns a, b, c, d and R (calculated), listing rows of integer side combinations with computed values such as 2.002602473 and 6.144179927.
Spreadsheet screenshot with columns a, b, c, d and R (calculated), listing rows 413 to 432 of integer side combinations with R values such as 6.750824126 and 7.467213691.
No case has integer r.
@Charles Link you have got the smallest. How have you got it ?
There is an intriguing case for ##r=7## reminiscent of the case where ##x=(3,\frac{1}{23})## in the previous thread except both integers. Can anyone find it?
HINT: You have to drop the requirement that all sides be different.
Without even doing any calculations, it also has the solution of 7,7,7, 14.
Here are the first ten primitive solutions, meaning not including scaled solutions.
Grid of ten small diagrams, each showing a quadrilateral inscribed in a circle with its radius r and four side lengths in brackets; cases 1 to 10 are labelled, with the circle centre marked by a dot.
Notice there are two pairs of solutions for ##r=7## that share three chords where the figures include the center or are to one side and do not include the center such as cases #3 and case #6. The case of (7,7,7,14) is just case #1 scaled by 7 and is not primitive.
Let integers a,b,c,d be
$$1 \leq a \leq \ b \leq c \leq d \leq 2r $$
Some primitive cases
a=b=c=d :
$$r=\frac{a}{\sqrt{2}}$$
r is irrational.
a=b=c:
$$ r=a\sqrt{\frac{1}{3-\frac{d}{a}}}$$
Only d/a=2, 11/4, 26/9, 47/16,...,3-##\frac{1}{n^2}##,... for integer r.
b=c=d:
$$ r=b\sqrt{\frac{1}{3-\frac{a}{b}}}$$
r is not an integer.
a=b,c=d:
$$r=\frac{\sqrt{a^2+c^2}}{2}$$
r is (half-)integer for Pythagoras numbers a and c.
