Clarification about a Power screw's specifications please
  • Thread starter Thread starter bbq_build
    Power
17 replies · 2K views
bbq_build
Hello, I have a power screw. According to the specifications, it is M8x1.25. Does that mean the effective diameter of the thread is 8 mm while the pitch is 1.25 mm? Is the screw radius just 4mm?
From the internet, it looks like the lead angle is atan(Lead/(pi*effective diameter of the thread)) or atan(number of threads*Pitch)/(pi*effective diameter of the thread).
Could you please let me know how to find the number of threads and the lead (m/rev)? What is the lead angle in this case? Thanks in advance.
To your first paragraph: yes and yes.
The "nominal diameter" would be 8mm. That's the outer edge of the helix.
The pitch would be 1.25mm. That's the distance from one turn to the next on the helix.
I am not sure what you mean by "lead angle". If it is the angle that helix would make with the surface being screwed, it would be atan(pitch/(pi*diameter)).
In the simple case, the "lead" as you describe it, would be the pitch - except that you would have to convert from mm/rev to m/rev.
In the less simple case, the screw may not actually penetrate at the full rate if the hole it is moving through has not been pre-drilled.
CWatters said:
If you have one perhaps measure it :-)
What instrument do you recommend to measure the lead angle and the thread angle?
I want to know the type of screw thread I have. It looks like I can tell the type if I can measure the thread angle.
Thanks. By "lead angle", I mean the one mentioned in:
https://en.wikipedia.org/wiki/Lead_(engineering)
http://www.mitsubishicarbide.com/en...c_threading_formula_top/tec_threading_formula
I think both refer to the same thing but please correct me if I am wrong.
For your reference, here is a photo of the thread I have:
https://www.flickr.com/photos/149564621@N02/shares/9878y6
Yes, they are the same. For the M8x1.25, there is only one helix.
Can use a micrometer to measure the diameter and just count the threads over say 10 or 20mm to work out the pitch.
I know. What about the lead angle and thread angle? Can they be measured by some kind of instrument that can be bought at hardware stores?
Nidum said:
That looks like a standard ISO thread .
https://en.wikipedia.org/wiki/ISO_metric_screw_thread
Thanks. Do I need to measure the thread angle to find out if it is ACME, Trapezoidal, Vee, Buttess, Round or square thread, etc? From the attached photo, can one tell what type it is? I got the power screw in Japan.
bbq_build said:
From the attached photo can one tell what type it is?
Yes . Almost certainly it is a 60 deg V thread .
That's a CAD image of a screw with true ISO 60 deg V thread form . See the similarity to the thread form on your screw ?
Nidum said:
That's a CAD image ofa screw with true ISO 60 deg V thread form . See the similarity to the thread form on your screw ?
They look quite similar but the one on top seem to have sharper crests and troughs. Do I have to concern about this?
I need to find the coefficient of kinetic friction, coefficient of static friction, velocity threshold (m/s) and low pass filter constant.
In simple theory the coefficients of friction only depend on the materials of screw and nut and/or on lubrication conditions .
You'll have to explain to me what the velocity threshold and low pass filter constant for a screw thread are .
Brass against Aluminium is a very poor materials combination to use in any kind of bearing application .
For your brass screw a non metallic nut would be better . Consider Nylon or PTFE .
Thanks. That is interesting but I am modelling a product that I bought. The screw is brass and the nut is aluminum.
There are some methods like 2wire,3 wire measuring methods for measuring the depth and dia of the screw threads. And these vary for thread to thread. That is type of the thread
Yes you are correct. 8 is the nominal diameter in mm, 1.25 is the pitch in mm and M stands for metric. Lead is the distance traveled by the nut measured parallel to the screw axis in 1turn. Lead angle is the inclination of the thread with the screw axis. If you don't mine, I suggest you a square thread for Power transmission rather than others. Because square threads are ment for power transmission only. I doesn't mean that other screws can't transmit the power. Yes, they can but as not efficient that those of square ones can!
