Calculate Revival Time of a Wave in Griffiths' QM 2nd Ed.
  • Context: Undergrad
  • Thread starter Thread starter Abhishek11235
    Classical Time
The discussion focuses on calculating the revival time of a wave as presented in Griffiths' "Quantum Mechanics" 2nd edition, specifically in Chapter 2. Two methods are proposed for this calculation: Method 1 derives the revival time using the oscillation time period formula, resulting in $$T= \sqrt{2m/E}×a×π$$, while Method 2 uses average velocity to yield $$T= a\sqrt{2E/m}$$. The conclusion identifies Method 2 as correct, emphasizing the importance of dimensional analysis and the context of the infinite square well potential in determining the revival time, which is given by $$T=4ma^2/\pi\hbar$$.
  • Understanding of quantum mechanics principles, particularly wave functions.
  • Familiarity with the concept of revival time in quantum systems.
  • Knowledge of oscillation and energy equations in classical mechanics.
  • Ability to perform dimensional analysis in physics equations.
  • Study the derivation of revival time in quantum mechanics, focusing on infinite square wells.
  • Learn about the implications of quantum revival times on wave function behavior.
  • Explore the differences between classical and quantum mechanical oscillators.
  • Review dimensional analysis techniques in physics to ensure correct unit consistency in equations.
Students and educators in quantum mechanics, physicists analyzing wave functions, and anyone interested in the mathematical foundations of revival times in quantum systems.
Abhishek11235
In Griffiths,Quantum Mechanics 2nd edition,Chapter 2,he gives a problem to calculate the revival time of a wave. Revival time is defined as the time taken by a wave to go from one side(x=0) to other side(x=a). Now let's calculate the revival time with 2 methods.
Method 1:
Now to go from 1 position to other and coming back to same place is 1 oscillation. The time period of Oscillation is:
$$T= 2π/\omega $$
We have $$E= 1/2 ka^2$$ where E is energy and a is width or amplitude. Since $$k=m(\omega)^2$$ we have after substituting in energy equation and then in the Equation for time period we find:
Method 2:
Now,by defination,the particle covers distance 2a with average velocity v given by:
$$v=\sqrt{2E/m}$$
So ##vT=2a## gives
$$T= a\sqrt{2E/m}$$
The question is why the above 2 methods give different result?
After checking solution manual,I found method 2 answer to be correct.
The problem in Griffiths (2.39) states "Show that the wave function of a particle in the infinite square well returns to its original form after a quantum revival time ##T=4ma^2/\pi\hbar##. That is ##\Psi(x,T)=\Psi(x,0)## for any state, (not just a stationary state)." I assume you are interested in part (b) which asks "What is the classical revival time, for a particle of energy E bouncing back and forth between the walls?" Well, your method 2 doesn't have the correct dimensions for ##T##. Check your algebra. Your method 1 has the energy expression ##E=1/2ka^2##. What is ##k##? If it's some kind of spring constant, note that the potential is a box with infinite walls not a harmonic oscillator potential.
