Finding the Closed Form of a Power Series
The discussion focuses on finding the closed form of the power series \(\sum_{n=0}^{\infty} n^2 x^n\) using the geometric series identity \(\frac{1}{1-x} = \sum_{n=0}^{\infty} x^n\) for \(|x|<1\). Participants suggest manipulating the series through differentiation and integration, specifically using \(f'(x) = \sum_{n=0}^{\infty} (n+1)^2 x^n\) and exploring the derivatives of the geometric series. The key insight is to express \(n^2 x^n\) in terms of derivatives of simpler series, leading to a closed form solution.
  • Understanding of power series and convergence criteria
  • Familiarity with geometric series and their properties
  • Basic knowledge of calculus, specifically differentiation and integration of series
  • Experience with manipulating series expressions and applying summation techniques
  • Study the derivation of closed forms for power series, focusing on \(\sum_{n=0}^{\infty} n^k x^n\)
  • Learn about the application of the geometric series in solving series problems
  • Explore the relationship between derivatives of power series and their closed forms
  • Investigate advanced techniques in series manipulation, such as generating functions
Mathematicians, students studying calculus and series, and anyone interested in advanced techniques for summing power series.
Yagoda
Using that \frac{1}{1-x} = \sum_{n=0}^{\infty} x^n for |x|<1 and that
f&#039;(x) =\sum_{n=0}^{\infty} (n+1)a_{n+1}(x-x_0)^n, write \sum_{n=0}^{\infty} n^2x^n in closed form.
In this series, a_n = n^2 and x_0 = 0. Applying the theorem I get that f&#039;(x) =\sum_{n=0}^{\infty} (n+1)(n+1)^2(x)^n = \sum_{n=0}^{\infty} (n+1)^3(x)^n. I know I want to try to apply the sum of the geometric series and then integrate to get f(x) (or maybe those things in reverse order), but the (n+1)^3 is giving me trouble.
I think you failed to define f(x) - is that 1/(1 - x) or a general function ##f(x) = \sum_{n = 0}^\infty a_n x^n## ?
Consider this:
$$\sum_{n = 0}^\infty n^2 x^n = \sum_{n = 1}^\infty n^2 x^n = \sum_{n = 0}^\infty (n + 1)^2 x^{n + 1} = x \sum_{n = 0}^\infty (n + 1) (n + 1) x^n$$
and try taking it from there.
I am considering f(x) to be the closed form of the series that I'm looking for so I use the theorem to find its derivative f'(x) and then hopefully find f itself. So what I've got so far is that given f'(x), f(x) =\sum_{n=0}^{\infty} (n+1)^2(x)^n, which tell us that f(x) =\sum_{n=0}^{\infty} (n+1)^2(x)^n =\sum_{n=0}^{\infty} n^2x^n since that was the original series, if that makes sense.
Maybe this is an elementary question, but is there a way to apply the geometric series identity to your expression to get a closed form or does some other type manipulation that I'm not seeing have to be done?
n^2 x^n = x \frac{d}{dx}\left( x \frac{d}{dx} x^n \right).
Alternatively, if ##g(x) = \sum x^n,## look at the series for ##g'(x)## and ##g''(x).## Can you see how to get ##\sum n^2 x^n## from those two series?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
