CO2 molecule oscillation mode 2 frequency derivation
8 replies · 4K views
johnconnor
A model of the carbon dioxide (CO2) molecule is constructed as shown in Fig. SM10.1
Two sliders A and C, each of mass M, represent the oxygen atoms and are connected by light springs, of force constant k, to a slider B of mass m, representing the carbon atom. All three sliders are placed on a linear air track. The two important modes of oscillation along the axis of the model molecule are as follows:
Mode 1: B remains stationary, and A and C oscillate so that the centre of mass of the model molecule remains stationary
Mode 2: A and C move equal distances in one direction, and B moves in the opposite direction in such a way that the centre of mass again remains stationary.
Show that the frequency f of mode 2 is given by [tex]f = (1/2\pi) [(k/M) + (2k/m)]^{1/2}[/tex]
Attempt:
Forgive me for my messy working:
[tex]\text{In\ equilibrium,} zm = M (2y)[/tex]
I came to me that the centre of mass of the system should remain unchanged throughout the motion, but how exactly do I justify the statement? Can I say "because there is no net force acting on the system, the centre of mass remains the same throughout the motion"?
Also, I am able to obtain the about equation f if I consider the motion in C. Could someone please show me how to obtain the same equation using B?
Can anybody explain to me how
in equilibrium, [tex]zm = M (2y)[/tex]
actually came about?
Thank you!
Hi johnconnor. So if we consider the motion of mass b: the force acting on b will be [itex]m\ddot{x}_b=k{\Delta}x_{ab}+k{\Delta}x_{bc}[/itex]. You can find the extension and direction of the force by considering displacing a slightly, and displacing b a very large distance in the same direction, the extension of this would be [itex]{\Delta}x_{ab}=x_b-x_a[/itex] and is directed against [itex]x_b[/itex], therefore: [itex]F_{ab}=-k(x_b-x_a)[/itex]. Use a similar approach to determine the effects of c on b. The position of the centre of mass of the system is just [itex]R=\frac{Mx_a+mx_b+Mx_c}{2M+m}=0[/itex]. Using the fact that [itex]x_a=x_c[/itex] for mode 2 for the centre of mass equation will give [itex]zm=2My[/itex] and for the equation of motion of b along with [itex]zm=2My[/itex] will give the SHM equation where you should be able to see what the angular frequency of mode 2 will be.
As in displacing "a" and "b" both to the left, but only the displacement of "b" is much greater than "a"? Isn't that contradictory to mode 2? Assuming that "a" is displaced slightly to the right, and "b" is displaced more to the left, then why is that [itex]{\Delta}x_{ab}=x_b-x_a[/itex]?
Don't you need a reference point to calculate centre of mass of a composite object? If we take moments at the LHS of A, then how is that the equation [itex]R=\frac{Mx_a+mx_b+Mx_c}{2M+m}[/itex] equals zero? Please point out what I'm missing out over here.
Similarly, where did the "z" come from? Up to now we've considered [itex]x_{ab}, x{bc}[/itex] etc, but never once a "z"...
I suggested this method for a way of figuring the forces on any mass due to a spring regardless of which mode/modes it is in. Because from this it gives a general 2nd order differential equation of motion for the mass, in solving, integration constants will appear which are determined by the initial conditions of the system which decide whether it'll be 1st mode, 2nd mode or a linear sum of both. Using this method it doesn't matter which way you extend the masses or which is extended the most, it will give the same answer for the force (it's just a hypothetical situation, the displacement of each spring can be anything). It is just easier if you extend one slightly and the other a large displacement.
Trying to remember how I arrived at that. I'm not to sure, I'll come back to you on that one.
y and z are just the displacement of the masses for the specific situation of mode 2, so [itex]x_a=x_c=y[/itex] and [itex]x_b=z[/itex], for mode 2.
zm=M(2y)
Since there is no external force acting on the body, the momentum is conserved. Simply use momentum conservation law on the A-B-C system.
Using the same idea you did in your attempt, you should be able to find the force on B due to the spring. The frequency of B will of course be the same as that of A and C. What would be the force on B? How can you relate this force to the differential equation for SHM?
Taking moment from the left.
New moment of A,C (move to right)=MAy + MCy
To maintain equilibrium mB has to move to the left in equal moment.
mz=2My
By considering the forces acting on B by masses A and B, I am able to come up with the formula F=k(y+z). However by doing that I am ignoring the forces on the right, and that the formula I obtained at the end is divided by a factor of surd 2. What am I doing wrong over here?
Can somebody please show me a partial solution for this one? I gave been really busy and I'm WAAAAY behind my schedule. Thank you...!
You have made a mistake taking the force on B. Its not [itex]k(y+z)[/itex] but instead, [itex]2k(y+z)[/itex]
