Chemistry CO2 and H2CO3 Concentrations in Aqueous Solution: Understanding the Relationship
  • Thread starter Thread starter i_love_science
    Co2
The discussion clarifies that in an aqueous solution, the concentration of CO2 is equal to the concentration of H2CO3, allowing for simplified calculations. While CO2 does not completely convert to H2CO3 upon dissolution, an equilibrium exists between CO2, H2O, and H2CO3. The rapid nature of this reaction permits the assumption that all CO2 is converted into carbonic acid for practical purposes, despite the nuances of the dissociation constant (Ka) being affected. This assumption is valid for solving related problems.
  • Understanding of acid-base chemistry
  • Familiarity with chemical equilibrium concepts
  • Knowledge of carbonic acid (H2CO3) properties
  • Basic principles of aqueous solutions
  • Research the equilibrium constant (Ka) for carbonic acid
  • Study the dissociation process of carbonic acid in aqueous solutions
  • Learn about the role of CO2 in acid-base reactions
  • Explore the effects of pH on the solubility of gases in water
Chemistry students, environmental scientists, and professionals studying aqueous solutions and acid-base equilibria will benefit from this discussion.
i_love_science
A chemist dissolves 0.135 mole of CO2(g) in 2.50 L of 0.105 M Na2CO3. Calculate the pH of the resulting solution.
pH
The solution says that the concentration of CO2 is equal to the concentration of H2CO3, which can be used to solve the rest of the problem. Does CO2 turn completely into H2CO3 when dissolved in aqueous solution? Thanks.
Well the solution is a aqueous - it is also alkaline. So what is there in solution (what ions?) already when the CO2 is thrown in, and what is any carbonic acid molecule going to do in that solution? (What do acids do?)
Actually we don't know - but it doesn't matter. There is definitely some equilibrium between CO2, H2O and H2CO3, but the reaction is so fast we can safely assume that equilibrium to be just part of the H2CO3 dissociation - it changes Ka a bit, but the value of Ka we OBSERVE already takes into account. So you can safely assume all carbon dioxide gets converted into carbonic acid and use this assumption as a starting point of the calculations, even if it is not entirely correct, the result will be OK.
Likes i_love_science
17K
  • · Replies 20 ·
