Understanding the Relationship between Weak and Strong Topologies
This discussion clarifies the relationship between weak and strong topologies, specifically the trivial topology and the discrete topology. It establishes that the trivial topology, denoted as {∅, X}, is a subset of the discrete topology, represented as 2^X, making it the weakest topology. The participants confirm that T_1 is weaker than T_2 if T_1 ⊆ T_2, with at least one set in T_2 not in T_1. The conversation emphasizes the definitions and properties of topologies on a set X, concluding that the trivial topology is the weakest and the discrete topology is the strongest.
  • Understanding of basic topology concepts, including open sets and topological spaces.
  • Familiarity with the definitions of trivial and discrete topologies.
  • Knowledge of set theory, particularly power sets and subset relations.
  • Ability to interpret mathematical notation, such as T_1 ⊆ T_2.
  • Study the properties of topological spaces in detail, focusing on open and closed sets.
  • Explore the concept of basis for a topology and how it relates to weak and strong topologies.
  • Learn about the different types of topologies, including metric and order topologies.
  • Investigate the implications of topology in functional analysis and its applications.
Mathematicians, students of topology, and anyone interested in understanding the foundational concepts of topological spaces and their relationships.
shinobi20
Verify that the “weakest” (coarsest) possible topology on a set ##X## is given by the trivial topology, where ∅ and ##X## represent the only open sets available, whereas the “strongest” (finest) topology is the discrete topology, where every subset is open.
1. ∅ ∈ {τ}, ##X## ∈ {τ};
2. the union (of an arbitrary number) of elements from {τ} is again in {τ};
3. the intersection of a finite number of elements from {τ} is again in {τ}.
I do not understand what is to verify here. The problem already defined what it means to be a trivial and discrete topology but it did not state what it means to be "weak" and "strong". I assume the problem wants me to connect "weak" with trivial topology and "strong" with discrete topology, but somehow the problem is not very clear to me or I just do not know how to connect them. Please guide me but do not give me the solution.
T_1 is weaker than T_2 iff T_1 \subsetneq T_2 (ie. every set which is open in T_1 is open in T_2, and there is at least one set which is open in T_2 but not in T_1.
Did you mean ##T_2 \subsetneq T_1##? Clearly (I'll prove this but I'm just clarifying what you said), the trivial topology is a subset of the discrete topology but not the other way.
The inclusion need not be strict, or at least this definition is not standard.
Given a set ##X##, there are multiple possible topologies on ##X##. Say we are given topologies ##\tau_1## and ##\tau_2## on ##X##. Then ##\tau_1 \subseteq \tau_2## means that ##\tau_1## is weaker than ##\tau_2## or equivalently ##\tau_2## is stronger than ##\tau_1##. This is just a definition.
Any set ##X## has a discrete topology ##2^X## (the power set of ##X##, i.e. all subsets of ##X## are open) and an indiscrete topology ##\{\emptyset, X\}##. It is quite trivial to see that these are topologies.
The question asks you to show that if ##\tau## is a topology on ##X##, then ##\{\emptyset, X\}\subseteq \tau \subseteq 2^X## and half a second of thought shows you that this is completely trivial.
I guess your confusion comes from the fact that this "problem" is so trivial that it is not clear what exactly there is to verify.
I meant what I said: \{\emptyset, X\} \subsetneq 2^X.
I'm not sure it makes sense to say that a topology is weaker than itself.
Of course that makes sense! Two topologies coincide when one is both weaker and stronger than the other. And take ##X=\{0\}##. The trivial topologies coincide so your strict inclusion is false.
This is contradictory to the statement of @Math_QED, which is
Math_QED said:
Given a set X, there are multiple possible topologies on X. Say we are given topologies τ1 and τ2 on X. Then τ1⊆τ2 means that τ1 is weaker than τ2 or equivalently τ2 is stronger than τ1. This is just a definition.
Math_QED said:
The question asks you to show that if τ is a topology on X, then {∅,X}⊆τ⊆2X and half a second of thought shows you that this is completely trivial.
If this is the question, then a simple proof should go as,
Proof. From the definition that in order to introduce a topology ##τ## on a set ##X##, the sets ##∅## and ##X## must belong to all possible topologies ##τ## of ##X##, then it is guaranteed that ##\{∅, X\}## is a subset of all ##τ## and since ##2^X## contains all subsets of ##X## it is guaranteed that all possible topologies ##τ## is a subset of ##2^X##.
This implies that ##\{∅, X\} ⊆ τ ⊆2^X##. So the trivial topology is the weakest and the discrete topology is the strongest.
Exactly, in other words, if we consider the set of all topologies on ##X## and we partially order it via the inclusion relation, then this set has both a minimum and a maximum.
Math_QED said:
Exactly, in other words, if we consider the set of all topologies on ##X## and we partially order it via the inclusion relation, then this set has both a minimum and a minimum.
I understand everything now. Thanks @Math_QED !
  • Love
  • · Replies 53 ·
