Coin on Turntable: Find Max Distance w/o Slipping
  • Thread starter Thread starter julz3216
    Turntable
The problem involves calculating the maximum distance a coin can be placed from the center of a turntable rotating at 45.0 rpm without slipping, given a coefficient of static friction of 0.186. The correct approach requires converting angular velocity from radians per second to linear velocity, using the relationship v = ωr. The final calculation shows that the maximum radius (r) is 0.082 meters, confirming the correct application of the formula mv²/r ≤ μs mg.
  • Understanding of angular velocity and its conversion to linear velocity
  • Familiarity with the concepts of static friction and its coefficient
  • Knowledge of Newton's second law as it applies to circular motion
  • Ability to manipulate algebraic equations to solve for unknowns
  • Study the relationship between angular velocity and linear velocity in circular motion
  • Explore the principles of static friction and its applications in physics problems
  • Learn how to derive and apply Newton's laws in circular motion scenarios
  • Practice solving similar problems involving friction on rotating surfaces
Students in physics courses, educators teaching mechanics, and anyone interested in understanding the dynamics of rotating systems and frictional forces.
julz3216
A coin is placed on a turntable that is rotating at 45.0 rpm. If the coefficient of static friction between the coin and the turntable is 0.186, how far from the center of the turntable can the coin be placed without having it slip off?
mv^2/r <= usmg
us= coefficient of static friction
I tried using the equation and I converted 45 rpms to rad/sec and I got r=12.17 but this is wrong so I don't know what to do. Maybe I am using the wrong equation?
Can you show more details of your calculations? We can't see what you've done wrong if you don't show your work.
mv^2/r =usmg
v^2/r = usg
(4.71^2)/r <= .186g
22.184 = 1.8228r
r= 12.17
This seems logical to me but it says it is wrong.
Note: the 4.71 rad/s, is angular velocity. You need to convert that to m/s, which is linear velocity. Do you know the relationship between these two? It should be in your textbook.
I think v = omega*r
Where v is the velocity, omega is angular speed (rad/s), and r is the radius.
so v= 4.71r
then (4.71r)^2/r= 22.18r = 1.8228
so r= .082
which is right! thank you!
You're welcome. :smile:
  • · Replies 20 ·
