Coin toss probability when not 50/50
  • Context: Undergrad
  • Thread starter Thread starter Mikes1098
    Probability
The discussion centers on the misconception regarding the probability of coin toss outcomes when previous results are considered. Participants clarify that coin tosses are independent events, meaning that the probability of getting heads remains at 0.5 regardless of prior flips if the coin is fair. They introduce Bayesian probability to assess the fairness of the coin based on observed outcomes, specifically using the formula P(p_heads = 0.5 | A_n) to update the probability as new data is collected. The key takeaway is that while past results can inform the likelihood of a coin being biased, they do not influence the outcome of future independent tosses.
  • Understanding of independent events in probability theory
  • Familiarity with Bayesian probability concepts
  • Knowledge of null hypothesis testing
  • Basic mathematical skills for probability calculations
  • Study Bayesian probability and its applications in hypothesis testing
  • Learn about the concept of independent events in probability theory
  • Explore null hypothesis significance testing in statistical analysis
  • Investigate the implications of biased coins and how to detect them
Statisticians, data analysts, educators in probability theory, and anyone interested in understanding the principles of independent events and Bayesian inference in probability assessments.
Mikes1098
I hopefully have a rather simple question... I am looking for the equation to calculate the probability when the total counts of heads and tails get off balance. To further explain, when I flip the coin once there is 50/50 chance getting one or the other... If I flip the coin 10,000 times that probability will get closer and closer to .5. However, on the way to 10,000 flips... Maybe after 100 flips, I might have 30 heads and 70 tails... Therefore my next flip should have have more of a chance of hitting heads (greater than .5 anyway)... How do I calculate that "improved" probability after the measuring x amount of data?
Thanks
If you are making independent tosses of fair coin that is not a correct deduction. There must be hundreds of threads on the forum about the fallacy of thinking this way.
If you are flipping the coin in some way that you can change the probability of getting a head and make it more or less than 0.5 then you could look at how many total heads you have and try to "balance things out" by changing the probability of tossing a head. But if you assume you are always tossing a fair coin then you are tossing a fair coin, regardless of the past history of heads and tails.
No. Coin tosses are independent; previous tosses have effect on future tosses.
As the previous posters have mentioned, if the coin is fair the probability of heads is 0.5 no matter what the previous sequence of heads and tails is.
At the risk of going beyond what you have learned so far, Mikes1098, you could ask a different question that does depend on the past sequence of heads and tails: is this a fair coin or not?
Using the Bayesian view of probability, you could calculate ##P(p_{heads} = 0.5 | A_n)## - the probability that the probability of the coin coming up heads is 0.5, given a that you have observed a sequence, ##A_n##, of n previous coin toss outcomes. This probability will change after each new flip, as each new flip gives you another data point that helps you decide whether or not the coin is fair. You would need some model for how each new data point changes your estimate of ##P(p_{heads} = 0.5 | A_n) \rightarrow P(p_{heads} = 0.5 | A_{n+1})##. However, it is very important to note that this still has no bearing whatsoever on what the outcome of the next coin toss is! It is only an estimate of the probability that the coin is fair! If this estimate is telling you that the probability that ##p_{heads} = 0.5## is small, however, then you may wish to start betting more on tails (however, ##P(p_{heads} = 0.5 | A_n)## doesn't tell you what the actual heads:tails ratio is).
ok, maybe the 100 flip example was a bit exaggerated... assuming it is a fair coin, after 10 flips it would not be shocking not to have perfect 5 heads and 5 tails. Eventually, which ever is behind will catch up after enough flips to equal the predicted .5... therefore doesn't the probability have to favor the one, that by chance, is lower? It seems there should be a way to take measured random data and alter the future probability have the remainder of the set.
Thanks Mute, that was exactly what I was looking for. I guess my definition of "fair coin" might have been off.
Just to be super super clear: the definition of a fair coin is one for which the probability of a "heads" outcome = probability of a "tails" outcome = 0.5 (for heads and tails being the only two outcomes). The situation I am describing is one in which you are observing a sequence of coins flips and trying to determine if you can reject the Null Hypothesis, which in the situation I posed would be "This is a fair coin" or more accurately, something like "This coin is not biased towards heads".
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 41 ·
  • · Replies 57 ·
  • · Replies 126 ·
9K
