Collecting gas over water with a eudiometer
elements
When, using a eudiometer in a lab to collect gas over water, if you have to switch eudiometers is the final volume of water displaced equal to the water displaced in the first tube + the water displaced in the second, and would the pressure be calculated through the total height displaced?
i.e.
Collecting butene gas from a reaction of BuBr and KOH in a 50mL eudiometer tube. The first tube all of the 50mL of H2O is displaced and the second tube 23mL is displaced.
Total Volume = Volume displaced in first tube + Volume displaced in second
Pressure = Pressure of both heights combined
Total Volume of gas produced = 50mL + 23mL=73mL of gas produced
Pressure = 50cm+(50-23cm)=770mmH2O
And what is the alternative?
just the final volume of water displaced in the second eudiometer tube
So, what its the reasoning behind ignoring the first portion of gas collected?
Imagine using twice larger tube - should you get the same result, or a different one from the same experiment? Would you get the same result if you ignore the volume collected in the first tube?
