Collisions - did I solve correctly
  • Thread starter Thread starter haki
    Collisions
The discussion revolves around verifying the solution to a physics problem involving a rock falling from a height of 20 meters and the average force exerted by the ground during its stop. The user correctly applies the principles of momentum and impulse, using energy conservation to relate potential energy to kinetic energy. The calculations lead to the expression for force as F = 729 * m, where m is the mass of the rock. Other participants confirm that the reasoning and calculations are accurate. The overall conclusion is that the user's approach to solving the problem is correct.
haki
Hi,
I would like somebody to verify if I have correctly solved a problem.
The problem is this: Rock of mass m falls from height 20 m to the ground. What is the average force of the ground acting on the rock if it takes 0.025 s to bring the rock to full stop. Express the force in relation to the mass of the rock.
Keywords that came to my mind are: Collisions, momentum, impusle, mom.-impul. theorem.
The trick should be in expressing the 2nd Newton law with momentum.
F = m*a is equivalent to F = p/t.
To get the momentum p. I would use energy conservation. all the potential energy goes to the kinetic energy just before the collision:
m*g*h=1/2*m*v^2 -> v = sqrt(2*g*h) soo
F = p/t
p=v*m
v=sqrt(2*g*h)
Solution:F= sqrt(2*g*h)*m/t Putting the numbers in it would get us:
F = sqrt(2*9.8*20)*m/0.025 = 729 * m
Was my resoning correct?
Yer, what you've done looks right
  • · Replies 17 ·
16K
