Comparing acidity of 2 substituted benzoic acids
  • Thread starter Thread starter Yashasvi Grover
    Acids
The discussion centers on the acidity comparison between anthranilic acid, salicylic acid, and benzoic acid. The original poster questions why anthranilic acid is less acidic than benzoic acid, despite the presence of an amino group that could stabilize the conjugate base through potential zwitterion formation. Various participants elaborate on the role of intramolecular hydrogen bonding and zwitterionic structures, noting that while salicylic acid exhibits stronger hydrogen bonding, anthranilic acid's neutral state is more stabilized than its ionized form, resulting in lower acidity. The conversation highlights discrepancies in pKa values from different sources, with some participants asserting that anthranilic acid has two pKa values due to the amino group. Ultimately, the consensus suggests that the order of acidity is salicylic acid > anthranilic acid > benzoic acid, while acknowledging the complexity and variability in reported pKa values across different references.
Yashasvi Grover
Ok so i am a beginner in organic chemistry and i came across comparing acidity.
Now according to various books i referred,anthranilic acid/ortho-amino benzoic acid is less acidic than benzoic acid.There was not sufficient explanation and therefore,my doubt.
According to my book,in o-hydroxy benzoic acid,the conjugate base is stabilized by hydrogen bonding between OH and COO negative ion,thus making the compound more acidic.
When i apply the same logic to this argument,apparently it fails.I want to know why.
Note-I am aware about nh2 being an exception to the ortho effect due to its small size.But Then by same logic,shouldnt OH be an exception too
Chemistry news on Phys.org
Note that the amine is a much better base than phenolic OH. Hence it may stabilize the acid function.
Thank for replying but can you please elaborate a little bit more.
I think he's talking about zwitter ion.
... Or at least an intramolecular hydrogen bridge.
EDIT: I now understand why you were talking about this. The title of this thread is quite misleading. The OP actually asks in the OP the difference in the chemistry behind why the acidity change between anthranilic acid and benzoic acid is different from acidity change between salicylic acid and benzoic acid.
In shorter words, he is asking why acidity decreases from benzoic acid to anthranilic acid, and NOT why anthranilic acid and salicylic acid have different acidity.The answer is most likely zwitterion.
Likes Yashasvi Grover
Something like this. Let's leave it open, to what percentage this is zwitterionic. Acylic amino groups are not as basic as aliphatic ones, so there will be some equilibrium. However, it is hard to say which side is really dominant.
Pardon me for my limited knowledge in organic chemistry,and therefore to know that i have grasped the concept i will explain what i understood and if i am wrong correct me please.If i am correct,acknowledge the same please.
So in Anthranilic acid there are adjacent base and acid;Therefore,there is a a possibility of transfer of H+ from COOH to NH2,forming a zwitter ion.
Now although COOH loses a proton,the molecule doesn't and therefore the acidity gets reduced as the probability of molecule losing its proton gets reduced.The extent of this reduction depends on the probability of zwitter ion formation,but it is safe to say that in comparison to simple benzoic acid,it(anthranilic acid ) is less acidic.
I thank you once more,It was really very helpful.
Hmmm...I am not sure if this argument provides a good insight.
These hydrogen bond will stabilize both the ionized state and not ionized state.
Your argument explains how hydrogen is prevented from leaving the molecule, and I believe salicylic acid to have the stronger intramolecular hydrogen bond than anthranilic acid. That means salicylic acid should show even weaker acidity than anthranilic acid, compared to benzoic acid from this perspective. In the ionized state, the salicylic acid would still show stronger hydrogen bond than anthranilic acid. That means salicylic acid should show even stronger acidity than anthranilic acid, compared to benzoic acid. In summary:
Since we already know the result, the above argument says that in the case of anthranilic acid, the ionized state stabilization effect is weaker than non-ionized state stabilization effect, while the opposite applies for salicylic acid. I don't think this can provide any good insight into why anthranilic acid show weaker acidity than benzoic acid while salicylic acid show stronger acidity than benzoic acid. Due to the qualitative nature of the explanation, we cannot judge which effect dominates over the other.
The explanation of the zwitterion, in comparison, can clearly explain OP's question.
From Wikipedia, here are the pKa values for each of the carboxylate groups:
benzoic acid pKa = 4.202
2-aminobenzoic acid pKa = 2.14
2-hydroxybenzoic acid pKa = 2.97
So, 2-aminobenzoic acid is more acidic than benzoic acid, and it is also more acidic than 2-hydroxybenozic acid.
Therefore, it is likely that intramolecular hydrogen bonding stabilizes the conjugate base of both 2-aminobenzoic acid and 2-hydroxybenzoic acid. 2-aminohydroxybenozic acid is more acid than 2-hydroxybenzoic acid because of zwitterionic effects (i.e. the positively charged ammonium group will help to stabilize the neighboring negatively charged carboxylate in the conjugate base).
Yes, but the amine being much more basic than the hydroxide, it will be a better hydrogen bond acceptor and worse hydrogen bond donator. I.e., comparing anthranilic and salicylic acid, in the former the unionized state will be relatively more stabilized than the ionized state resulting in a lower acidity.
Btw, the Zwitterionic structure of anthranilic acid has higher energy than the nonionic form of anthranilic acid, i.e, it can't be used to explain the higher pKa:
http://www.mdpi.com/1422-0067/15/11/19562/htm
I think wikis pka values are wrong.My book says it is weaker than Benzoic
And moreover salylic acid has stronger H bonding-correct But
According to my book it says that HBonding is possible in both ionised and unionised state,But as we know O negative forms stronger H bond than simple O ie it stabilises conjugate base more than undissociated acid and therefore probability of H bonding is more in conjugate base rather than undissociated state,therefore salicylic acid is stronger but as Nh3 forms zwitter ion instead,the same argument doesn't apply.
I think I have got it.
I Use Peter Sykes as my reference book
As I mentioned above, literature excludes the formation of zwitter ions in anthranilic acid.
Ygggdrasil showed that both anthranilic acid and salicylic acid are stronger than benzoic acid, so you are right that the anions are more strongly stabilized than the neutral acids in both anthranilic and salicylic acid whence both have a lower pKa than benzoic acid. However, comparing salicylic and anthranilic acid, the neutral acid is more strongly stabilized in the case of anthranilic acid, whence it is a weaker acid than salicylic acid.
ok so to conclude,Relative order of acidity is Salicyclic acid>anthranilic acid>benzoic acid.
Thank you guys for your inputs.
See
https://www.iupac.org/publications/pac/pdf/1960/pdf/0102x0187.pdf
Due to the amino group, Anthranilic acid has 2 pKa values, one about 2 and the other about 5. the first one is the relevant one in the context of your question.
In order from most acidic to least acidic: 2-aminobenzoic acid, 2-hydroxybenzoic acid, benzoic acid.
Here are the pKa values for the carboxylic acids from the NIH database:
Benzoic acid: 4.204 https://pubchem.ncbi.nlm.nih.gov/compound/243#section=Dissociation-Constants
2-hydroxybenzoic acid: 2.98 https://pubchem.ncbi.nlm.nih.gov/compound/338#section=Dissociation-Constants
2-aminobenzoic acid: 2.14 https://pubchem.ncbi.nlm.nih.gov/compound/227#section=Dissociation-Constants
Why god why? LOL
Somebody explain now why salicyclic is weaker
So many different sources saying so many different pKas for the molecules, and every time I have to change my interpretation. lol. At this point, I almost feel like doing the experiments myself to see for myself. I do not have a free pH meter available right now, so I can't do that.
Can someone confirm the sources? The sources provided by Ygggdrasil seems to be from different sources. Also, the temperature is different (and is not provided for anthranilic acid).
