Compensating for Gravity in Archery: Finding the Correct Aim Point
  • Thread starter Thread starter halo9909
    Displacement
5 replies · 2K views
halo9909
An archer stands 39.0 m from the target. If the arrow is shot horizontally with a velocity of 86.0 m/s, how far above the bull's-eye must he aim to compensate for gravity pulling his arrow downward?
d=vit + at^2
I ended up getting 2.01m but am sure if that is correct and would like to know if I am not how to go about this, since it is confusing, when you don't know what formulas should/can be used
i got it now its 1.007m
cant exactly remmeber, keep dividing and multuiplying it and got it
wow that works now? I wish I had that talent
I also got the same result as you, but my method was a little more complicated than just "multiplying and dividing" until I got the answer. How about we share our approaches so as we can learn a little something off each other?
Mine:
1) I calculated the time of flight using [tex]\Delta x=v_{x}t[/tex]
2) Using that result, found the intial vertical velocity using [tex]\Delta x=v_{i}t+\frac{1}{2}at^{2}[/tex]
3) I was then able to find the acute angle that the arrow had to make with the horizontal by trigonometry and the velocity vectors (vx=86,vy=result from 2), by using [tex]\theta=tan^{-1}(\frac{v_{iy}}{v_{ix}})[/tex]
4) Once I found the angle of the arrow to the horizontal, I could find exactly how far above the bullseye the arrow was pointing at by considering the distance between the arrow and target and using trigonometry: [tex]h=\Delta x.tan\theta[/tex]
From the sound of it, you have taken another approach which sounds more simple. If possible, could you please share your solution?
