Compilation problem with gfortran
  • Context: Fortran
  • Thread starter Thread starter leroygr
    Gfortran
9 replies · 9K views
leroygr
Hello everyone,
I'm trying since a few days to compile a f90 program with gfortran (on Ubuntu) with a makefile. The fortran program calls 2 routines written in C.
Here is my makefile:
Code:
FC              =       gfortran
SFC             =       gfortran
FFLAGS          =       -ffree-form -O -fconvert=big-endian -frecord-marker=4
F77FLAGS        =       -ffixed-form -O -fconvert=big-endian -frecord-marker=4
FNGFLAGS        =       $(FFLAGS)
LDFLAGS         =
CC              =       gcc
SCC             =       gcc
CFLAGS          =
CPP             =       /usr/bin/cpp -C -P -traditional
CPPFLAGS        =       -D_UNDERSCORE -DBYTESWAP -DLINUX -DIO_NETCDF -DBIT32 -DNO_SIGNAL
RANLIB          =       ranlib
all: rd_wr_formatted.exe
clean:
    rm -f *.o rd_wr_formatted.exe
rd_wr_formatted.exe: rd_wr_formatted.o read_geogrid.o write_geogrid.o
    $(FC) $(LDFLAGS) -o rd_wr_formatted.exe rd_wr_formatted.o read_geogrid.o write_geogrid.o
rd_wr_formatted.o: rd_wr_formatted.f90
    $(FC) -c $(FFLAGS) rd_wr_formatted.f90
read_geogrid.o: read_geogrid.c
    $(CC) -c $(CFLAGS) read_geogrid.c
write_geogrid.o: write_geogrid.c
    $(CC) -c $(CFLAGS) write_geogrid.c
Here is my fortran 90 program code:
Code:
program rd_wr_binary
   implicit none
   integer, external :: iargc
   integer :: istatus
   character (len=256) :: fname
   real, allocatable, dimension(:,:) :: rarray
!   real, allocatable, dimension(:,:) :: rarrayIN
   integer :: nx           ! x-dimension of the array
   integer :: ny           ! y-dimension of the array
   integer :: nz           ! z-dimension of the array
   integer :: isigned      ! 0=unsigned data, 1=signed data
   integer :: endian       ! 0=big endian, 1=little endian
   real :: scalefactor     ! value to divide array elements by before truncation to integers
   integer :: wordsize     ! number of bytes to use for each array element
   integer :: i
   integer :: j
   if (iargc /= 1) then
     write(0,*) ' '
     write(0,*) 'Usage: rd_wr_binary.exe <filename>'
     write(0,*) ' '
     stop
   end if
   call getarg(1, fname)
   ! The following must be set before compiling
   nx = 1200
   ny = 1200
   nz = 1
   isigned = 0
   endian = 0
   wordsize = 4
   scalefactor = 1.0
!   allocate(rarrayIN(nx,ny))
   allocate(rarray(nx,ny))
   ! Read data from geogrid binary format using read_geogrid()
!   call read_geogrid(fname, len_trim(fname), rarray, nx, ny, nz, isigned, endian, scalefactor, wordsize, istatus)
!   if (istatus /= 0) then
!      write(0,*) 'Error while reading '//trim(fname)//'. Quitting.'
!   end if
! We read formatted data instead of binary input file
    open(10, file=trim(fname), form='formatted', status='old')
    do j=1,ny
       read(10,33) (rarray(i,j),i=1,nx)
       write(*,*) i,j,rarray(nx,j)
    end do
 33    format(f6.1, 12000f7.1)
! 33    format(18500f7.1)
   close(10)
! ------------ IF we need FLIP file -----
!      NO FLIP file!
!        do j = 1,ny
!          do i = 1,nx
!            rarray(i,j) = rarrayIN(i,j)
!          enddo
!            write(*,*) i,j,rarray(nx,j)
!        enddo
!--------------- end of FLIP/no FLIP ----
   ! Modify the field as necessary
   ! Write data to geogrid binary format using write_geogrid()
   call write_geogrid(trim(fname)//'.bin', len_trim(trim(fname)//'.bin'), rarray, nx, ny, nz, isigned, endian, scalefactor, wordsize)
!   deallocate(rarrayIN)
   deallocate(rarray)
   write(0,*) 'JOB finished OK!'
end program rd_wr_binary
When I try to compile using "make" command, I get this error message that I don't understand:
Code:
[greg@Uranus:~/WRF/WPS/data/SRTM_to_geogrid]$ make
gfortran -c -ffree-form -O -fconvert=big-endian -frecord-marker=4 rd_wr_formatted.f90
rd_wr_formatted.f90:25.12:
Error: Function 'iargc' requires an argument list at (1)
rd_wr_formatted.f90:30.6:
   end if
Error: Expecting END PROGRAM statement at (1)
rd_wr_formatted.f90:90.132:
Error: Syntax error in argument list at (1)
Warning: Line truncated at (1)
make: *** [rd_wr_formatted.o] Error 1
Can someone help me? I'm really really blocked...
Thank you very much!
Greg
on Phys.org
With the statement,
Code:
Are you trying to say "if iargc does not equal 1, then..."? If so, I would recommend using,
Code:
if (iargc .ne. 1) then
I'm not sure about the "Error: Expecting END PROGRAM statement", but it could have to do with the "stop" being there. See if ".ne." changes that. The last two errors you are getting are due to Fortran truncating programs at the 72nd column by default. If you type out something like,
Code:
!23456789012345678901234567890123456789012345678901234567890123456789012
Somewhere in your program, you can tell what line to do continuations at. Making those multiple line statements will fix those errors.
Hope that helped.
It doesn't look like anything is wrong with your makefile, just the code.
Yes indeed.
I did the modification you proposed but I got the same error...
The compiler thinks iargc is an external function and not an integer. After doing a web search, iargc is a function. You'll need to add code like this:
Code:
      integer argcount
      argcount = iargc()
      if(1 /= argcount)then
I don't know if this is allowed
Code:
      if(1 /= iargc() )then
Why is iargc defined as external?
I don't know exactly why... To be honest I'm not the author of the program. I try to use it for SRTM data to WRF geogrid binary data conversion. I understand what the program does generally, but unfortunately not all the code lines.
I'll try to add rcgldr's code.
I replaced
Code:
     write(0,*) ' '
     write(0,*) ' '
    ! stop
   end if
by
Code:
 if (iargc() /= 1) then
     write(0,*) ' '
     write(0,*) ' '
    ! stop
   end if
It is better by I have the following errors now:
Code:
[greg@Uranus:~/WRF/WPS/data/SRTM_conversion]$ make
gfortran  -o rd_wr_formatted.exe rd_wr_formatted.o read_geogrid.o write_geogrid.o
rd_wr_formatted.o: In function `MAIN__':
rd_wr_formatted.f90:(.text+0x39): undefined reference to `iargc_'
rd_wr_formatted.f90:(.text+0x639): undefined reference to `write_geogrid_'
collect2: ld returned 1 exit status
make: *** [rd_wr_formatted.exe] Error 1
Any idea?
leroygr said:
Any idea?
You need to include library names in the make file for the link step. Apparently it's not defaulting to include the libraries you need to use iargc().
Ok! Can you explain to me how to do that? (I'm quite a newbie sorry ...)
