Completely Factor 32x^5 + 243y^5 Using Synthetic Division | Step-by-Step Guide
  • Thread starter Thread starter Plutonium88
6 replies · 5K views
Plutonium88
Completely factor 32x^5 + 243y^5
okay i used synthetic divison and i referenced a factorign calculator to get the answer
Answer: i used f(x) = (2x)^5 + (3y)^5
then f(-3y/2)= (2x)^5 + (3y)^5 = 0 (factor thereom)
using synthetic divison and factor (-3y/2)
i got.. 32x^4 -48x^3y + 72x^2y^2 -108xy^3 + 162y^4
The answer is (2x+3y)(16x^4 -24x^3y + 36x^2y^2 - 54xy^3 + 81y^4)
i notice that the second piece (16x^4...)
the whole piece is actually half of what i long divided..so my problem is why am i not dividing to get that answer? and how can i put together what i knowÉ
Answer:
So what you have is
(2x)5 + (3y)5 = (x - (-3y/2))(32x4 -48x3y + 72x2y2 -108xy3 + 162y4)
= (x + 3y/2)(32x4 -48x3y + 72x2y2 -108xy3 + 162y4)
If you pull a factor of 2 out of the long factor, and use it to multiply the first factor, you get what you show below.
Mark44 said:
So what you have is
Just out of curiosity why am i allowed to divide a two out of the long factor, but i have to multiply it by the small factor? Like why is that allowed to happen, is there a rule of some sort... :O
Maybe this will help clear the confusion up:
Consider
[itex] \begin{eqnarray*}<br /> (\frac{a}{2}+\frac{b}{2})(2a + 2b) &=& \frac{2}{2} (\frac{a}{2}+\frac{b}{2})(2a + 2b)\\<br /> &=& 2 \cdot (\frac{a}{2}+\frac{b}{2}) \cdot \frac{(2a + 2b)}{2}\\<br /> &=& (a+b)(a + b)<br /> \end{eqnarray*}[/itex]
Does that help clear up what was done above?
Consider
So is this kind of a choice, of expanding the 2 within the first factor and using the 1/2 and targeting the second factor peicce with it.. argh I am just havin a rough time with this idea..
the onyl connection i can make (whichi 'm not sure is true) is it looks like you multiply the equation by (2/2) to satisfy both the top and bottom of the equation, and then the rules of math just do the rest... but that's just a guess..
Can u explain to me why you multiply the equation by 2/2
I was just illustrating why you can divide one term by 2 and multiply the other by 2. It's the same thing as multiplying by [itex]\frac{2}{2} = 1[/itex]. I just figured it was easier to see in a smaller example.
i understand that connection and looking at the smaller example in terms of the math(that is very clear).
I think i was just thinking about it to hard, or perhaps not in the right manner. thanks a gain for your help man.
